The pump will flow more than enough for whatever any of you need. The gears on the front of the crank pulley and the pump govern the speed of the pump. You'll generally drive the pump at half engine speed but I know Mark has a pretty good idea about where he likes the ratio to be.
Tomek - this is NOT a dry sump pump. It is an external wet sump pump.
All - yes air con is gay.
  • Replies 80
is this your car or your mums?
real cars have no air-con!
So are you going to answer the question or not?
This is not a full time dedicated track car yet! (working towards it).
I am already stupid enough to run around playing sport in the heat, doesn't mean I have to drive in it too after being in it all day. :)
I don't understand what specs you need.
Exactly...Mark has set two of these up....one is on his 7.84 R32 second race car....the other on his 1500hp dyno R34...you wont need to worry about what it flows etc...they will be a bolt up item that all the headwork has been done for you on it already. This set-up has been ran and tested on Australia's most powerful GTR's over the last 3+years.
They will be easy to install with all fittings and instructions and now no need to run an oil drive collar on your crank.
And they work.
easy
Edited by DiRTgarage
dunno how ur gonna use them with a std sump or a non modifed sump, caus they generally need an external pickup welded into the sump. Well u could weld a fitting onto the pickup side of a std pump, but not ideal IMO
also paul, for ease, you may want to try to sell ati balancers with them and their crank snout pulleys or its gonna be a pain to acoomodate everyone with their different balancers.
its possible to retain aricon etc, jsut make up an l-bracket and mount the pump under the alternator
i'll edit this tomororw with some pics after i put the sump on
Glad to see that Mark is finally releasing these to the public :)
For anyone with big power engines, these are an excellent choice in order to avoid the dreaded RB26 Busted/Broken Oil Pump (BOP) syndrome. Yes, even the JUN pumps are prone to the BOP syndrome.
oh ... :D should learn to read thread titles properly :(
Still interested thought.. Need to do some reading first thought ..
What happens to the regular off crank pump, im stumped.. works in succession at high revs, obviously.. like I said stumped.. :huh:
Have a look at the pics I posted and you'll see the feed from the new pickup in the sump pan. Here is a pic of a gutted standard pump with block-off.
****PLEASE NOTE****
This is just how I did it. I am not part of this group buy and I'm just trying to help Paul/Mark/The-Rest-Of-You out with some visuals.
the original pick-up is used and the existing oil pump is internally grub screwed and the 'guts' removed. The fittings are attached to the original pump where the welsh plugs are on it (if you have access to a pump you will see what i mean). We are looking at sourcing some 'busted' oil pumps and already modifing them as part of the group buy for ease of fitting. This will make it a truely bolt on proposition.
Thanks, would be good to see how you did it
Interested at this stage as well.
Whats the biggest advantage i am getting with this set up over the normal oil pump and crank collar set up?
Because it bolts onto a/c bracket, will it fit a 30 block?
Approx time frame? Anything a little more concrete on pricing?
Cheer Chris.
Cheer Chris.
yes it will be a while until all suppliers get back with exact costings. and final details...maybe 1 week...will fit your RB30.
Will fit an rb30 indeed. This one is on a 26/30 for a gtr.
Currently waiting on the crank snout to be machined b4 everything can be finished on it
Paul, if u want the cad files for the bracket let me know. Alternatively i can get a hole heap lasercut and send them down.
your bracket looks the goods and maybe the go as a lot of people will want to retain a/c. Might go that way or have both brackets available and then people can mount them where it suits them best. Ill be putting mine where the a/c went as i have plenty of room there and would 'even' things out a little in regards to room/space etc.
thanks for your input
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
