hey all,
im contemplating selling the 32.
1993 r32 gtst Mspec.
S2 RB25DET (120,000kms)
100,000km service done AGAIN at 120,000.
rb25det gearbox
heavy duty button clutch (excedy)
tailshaft modded by hardie spicer (500km's old)
just jap tube and fin FMIC (500km's old)
splitfires (200km's old)
nismo 555cc injectors (got the clean and flow test sheet)
z32 AFM
apexi AX53B70 p25 TURBO with braided lines.
isc N1 coilovers.
Eboost controller
apexi power fc and HC
3inch TURBO back exhaust with 3inch hiflow cat (hollowed out) to 4.5inch muffler (jasma)
ALL new nothlene bushes (with reciept)
some suspension work done (on reciept)
pioneer CD deck
mbquart splits
pioneer 6x9's
fully operational sunroof
16x7 +30 avs model 6's with brand new dunlop 3000
Paint is good but not the best. few chips and stuff.
car made 250.1RWKW @ 15psi with actuator not holding boost due to wastegate flapper opening :)
with a stiffer actuator it will make 270-280 easy.
very responsive and great to drive.. would smoke alot of cars out there...
there is also many things i have missed but ill update along the way if i remember lol..
have a folder with many reciepts in it :)
pictures will be up on weekend when i can take some good shots.
looking at $16,500 (spent atleast that on the car)
or will remove parts for cheaper sale..
will sell for $13k STOCK.
NEVER BEEN TRACKED.
0433290801 msg me and ill call you.
regards adrian
Edited by rad32
https://www.sau.com.au/forums/topic/252400-1993-r32-gtst-mspec-rb25det/
I did the RB25DET Conversion and wiring, made the Custom crossmember for the gearbox etc so i can assure you nothing has been skipped. Very good Value for money this car....Hardly driven with the rb25 and an all round package.
GL Adrian.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
