Hi All.
I guess lots of friends like me, after driving our V everyday for more than 2 years, realy get sick of old ugly big shifter knob.
Guys in G35 form replace it with aftermarket ones.
I personally like this very much.
But after search on ebay and goolge. the only thing I can find that looks not that bad is for Commondore!!!!!!!!!!!!!!!!!!
The other choice is this, more like a hand break other than a shifter knob.
Lets start discuss
Any suggestion welcome.
Edited by Frank350GT
Yes, the V35's factory leather wrapped shifter is considered a beauty compared to what I used to have in the R33, or basically any Nissan from the 90s era! Those ugly T bar shaped.... ugh...
Series 2 shifters are a lot nicer looking than s1 plus they come with the aluminium surround and leather boot
Yep, that is what I am looking for, That is why I prefer the M45 shifter knob.
Any idear where can get them?
cheers
  • 1 month later...
