Only had the car about one month and there are afew strange sounds that maybe someone here has encountered before.
NO:1, at idle, sounds sort of like a thrust bearing, but not as loud and high pitched, when the clutch is pushed in it goes away!
NO:2 when breaking just before the car stops (last 5 meters or so) the front left brake is making a "grating" sound and "feels" rough thru the pedal.
any help would be much apreciated!
https://www.sau.com.au/forums/topic/25256-strange-sounds-in-r32-gts-t/
i have the same noise with #2. Just when pulling up at lights for the last 10m there is a bit of a scraping noise, its not too bad, but i am gonna get it sused. When I bought it the guy said its had the discs machined and new pads. The discs feel pretty smooth, must be the pads...
yes it will make the noise in neutral, if you press the clutch it will disappear.....
i am afraid it is rather costly, so as i said if it isnt too loud dont worry, but if you insist get your gearbox rebuilt, i guess it will cost $2000 or more.
If it's the input bearing it will make a noise in neutral with the clutch out because you have:
engine -> clutch -> gearbox -> diff/road
gearbox has an input and output shaft, normally these are engaged in a gear but they're not connected in neutral - but with the clutch out the engine's still connected to the input side of things so the input shaft will spin with the engine.
Have a look at howstuffworks.com, pics will help.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
