Is it 1mm? I have had a look around and all the people that make them only make 1mm and up. So does that mean if i want some cheap compression my only option is to machine the head?
I have had a look around and cant find the cc of the RB20 head, i am guessing i cannot machine enough of the head to get compression up to around 8.5:1? I just want to cheaply bump up the compression i can...and give that i can get an RB20 head for $50 want to have a go at porting a head myself (I am after all the Butcher of Southbank)
https://www.sau.com.au/forums/topic/252632-std-rb20-head-gasket-thickness/
I have had a look around and cant find the cc of the RB20 head, i am guessing i cannot machine enough of the head to get compression up to around 8.5:1? I just want to cheaply bump up the compression i can...and give that i can get an RB20 head for $50 want to have a go at porting a head myself (I am after all the Butcher of Bangalore)
fixed
yes Roy they are 1mm
you could get a copper gasket made that would be thinner than 1mm
Isn't the standard compression 8.5:1? It's been a while since I worked that one out but I was fairly sure it was.
Type (see below) RB20DET Twin cam, in-line 6, Turbocharged
Displacement 1998 cc
Compression Ratio 8.5:1
Max. Power; kW/bhp 160/214 @ 6400 rpm
Max. Torque; Nm/ft-lbs 263/194 @ 3200 rpm
Bore x Stroke; mm 78 x 69.7
Redline 7600 rpm
Fuel Injection Nissan EGI (ECCS)
Head porting costs money, also, typically porting slows velocity so hurts low-mid rpm but helps high rpm flow. ??? Yes, No?
..not what comes to mind when wanting more torqe and response to spin a turbo up...ditto longer duration cams.
But i am all ears if you have actual before / after figures and a place that knows the right thing to do to a head. I am considering buying a cheap used head and just cleaning it up with knife edging etc...but no real porting.
I am happy to spend the money but dont want to be the guy paying for the experiment and piss poor results or backwards step. :D
...Just dawned on me that yes the RB20 is 8.5:1 a its half a point behind the RB25 at 9.0:1 so completely stuffed that up. :bunny:
Slows velocity but increases flow. Your engine is an air pump, the more air you can get in and out, the better. It improves both response and overall power potential. There is, of course, the possibility of porting too much and going backwards, but you have to take out an incredible amount to do this.
With camshafts, an increase in lift only is required for better response. That, and possibly some cam timing changes. A set of custom grind cams or even a set of GTR cams will do nicely. Time them with a set of gears and do a slight clean up of the cylinder head and you will get massive results.
Increasing compression by making the head gasket thinner is extremely poor practice. Using copper gaskets to do this is even worse and as far as expensive goes...o ringing your block and getting the copper gasket made would be the same cost as getting a head port.
If you want to talk to the king of porting, ring Marty White - 0733917533
Well before i waste Marty's time...are we talking about $800-$1500-$2000 for a head re-co and clean up/porting of head, inlet and exhaust? The idea is for me to give it a go myself, but if the dollars are not too ludicrous and the confidence is high that it will net tangible results then happt to do it
Hear what you are saying about air pump. But its the gas velocity at low-mid rpm that gives you cylinder filling which gives good combustion and good torque and the improved gas velocty spins the turbine with more torque sooner. I am happy enough with the 260rwkws, more would be great, but what i want is to fatten it up and make the same power easier. I just need a tad more grunt in 3rd gear at 4,000rpm . 30rwkw improvement at that point to make the same (give or take) peak power is what i need.
Basic head porting with 15% improvements will set you back around $800. Your best bet is to talk to Marty. Tell him everything you have said there and get his opinion. No one on this forum can argue he is probably the best in the industry. I do porting myself but whenever it comes to major re-construction I take them to him.
Meh...cost too much money and it may end up in the long run over time costing me more money but there is fun in tinkering and getting improvements on small spends. Without experimentation we would all be driving RB20s with high 253s or RB25s with GCG Hi-Flows ;)
  • 3 months later...
it freaked me out too.......
i am also thinking the same thing....
making the RB20s' compression slightly higher.
thus making driveability off boost better of the higher comp ratio.
**looking for RB20 head**
Edited by benz_200t
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
