how the hell did you get a 215 on a 9.5"! thats awesome.. i thought 235 on 9.5 was a bit of a stretch.
wasnt too hard, cant remember if we even needed to use a baby elephant or not, ive seen people go much bigger stretch, but i dont really like running anything smaller than 215.
What brand of 275's are you considering? If they are bargain basement specials, like Nankang or similar, they're probably not quite as wide as name brand 275's anyway.
The current HSV R8 has 275/35/19's on a 9.5 wide rim and they sit with a slight bit of stretch, so 275/xx/18 on a 9 will most likely sit pretty much dead square.
the tread is the same width, its usually the sidewalls which give the illusion if it being wider, they have thicker sidewalls and hence sit more square and look wider.
RE01Rs. I think that's quality.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
