i just copied this from the supanova site :P
A Novation Agreement– What is it ?.
A Novation Agreement, when used in conjunction with a vehicle lease represents an agreement between three parties being the employee (lessee), the financier and the employer. The employee leases the vehicle in their own name from the financier, then by attaching the Novation Agreement the following occurs.
-The employer takes over all the obligations of the lease except for the residual value which remains the obligation of the employee.
-These obligations remain whilst the employee remains employed. During this period the employer makes all lease payments to the financier from the employee’s salary.
-If employment is terminated, the Novation Agreement is rescinded (ceased) and only the lease agreement between the employee and the financier remains. When the employee leaves their employment they are required to take the vehicle with them.
https://www.sau.com.au/forums/topic/2529-leases/#findComment-46147
PeteSmith's is probably a 'conventional' lease, which is paid for with 'after-tax' money, ie take-home pay.
With a novated lease, you effectively pay for the lease with 'before-tax' money, by sacrificing some of your salary for the cost of the lease.
It can be an effective way to reduce PAYE tax, particulary if you are earning in the top tax bracket (> $50k), because it lowers your take-home pay, and the lower take-home pay attracts a lower tax rate.
https://www.sau.com.au/forums/topic/2529-leases/#findComment-46167
I can highly recommend Leaseplan.
I can highly recommend against Orix.
I am about to find out how good MacMillan-Shakespeare are...
If you work for a large company they may already have an agreement with a preferred fleet company... There are age restrictions on the cars you can lease with the bigger lease/fleet companies though.
Novated Leasing rocks if you set it up correctly, and drive enough km to get the FBT down :D
Any questions, let me know, I'm about to enter my second one :cool:
https://www.sau.com.au/forums/topic/2529-leases/#findComment-47138
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
