I'm spending a week near bicheno on the coast in feb and seriously thinking about
driving down from sydney, getting the ferry and driving there. (and back). So i was
wondering if there are any deserted drivers roads - of the kind top gear like to find
in wales or scotland, or if it is going to be a 100kmh snoozefest in traffic the whole way.
https://www.sau.com.au/forums/topic/252999-roads/
Top gear AUS have used tassy roads quite a bit for filming. nearly any direction you go you will find a lot of corners.
my mum is over from SA and she commented about how much fun it is to have more than 1 corner within 100km.
https://www.sau.com.au/forums/topic/252999-roads/#findComment-4374342
It's even worse here in WA, I'm keen to move back home and get my Skyline over there to some corners and i think i might have to get another road bike too hehe.
And while I'm here, What are the cops like for giving out yellow stickers or defects over there?
Because they just love giving them out over here, But all the time while i was growing up in Tassie i don't think i ever heard of anyone getting a defect unless the car was pretty well stuffed.
So do you guys get much trouble for Front mounts and the like?
Sorry for hijacking your thread dude :)
https://www.sau.com.au/forums/topic/252999-roads/#findComment-4374428
Sorry for hijacking your thread dude ;)
np, I'm interested in the answer to that as well..
https://www.sau.com.au/forums/topic/252999-roads/#findComment-4374649
not realy.
plenty os skylines running around with exernal gates. pods. Bov's. ect ect. low. bald tyres.
basicly if you atract their attention by speed or noise than they will book you but rearly defect cars.
my mate has been driving a r33 around for 6 months with sponsor stickers all over it and has only recently been pulled over and given a warning for it.
you would be un lucky to get caught basicly.
https://www.sau.com.au/forums/topic/252999-roads/#findComment-4374837
If it were me I would go this way Map
It takes in the sideling and a few other targa roads, and you get to drive down the coast a bit, which is good too :banana: Mind you, you cant go too wrong if youre after windy roads
i think you linked my original one again? .. but I'd be very interested to see yours.
https://www.sau.com.au/forums/topic/252999-roads/#findComment-4411929
How does this route look? I tried to aim for the most interesting wiggles.
http://maps.google.com/maps?f=d&source....191772&z=9
Most of this route is pretty good, but alot of the road from bakers beach to york town is a gravel forrestry road with alot of log trucks using it. Stay on the frankford road to beaconsfield. On your way back for a truly awesome drive go from bicheno up the coast to St Helens than take the Tasman Highway to Scottsdale. I did coming back from a trip on boxing day the road is awesome. :domokun:
https://www.sau.com.au/forums/topic/252999-roads/#findComment-4412300
Oops :domokun: try this one map or this image...
Edit: Ok I suck - just look at the picture!
that looks good! thanks, I'll try that on the way down..
if my choice turned into a dirt logging track i woulda cried.
(for google maps you gotta hit the share/link button and copy-paste the link displayed in the pop-up)
https://www.sau.com.au/forums/topic/252999-roads/#findComment-4412499
I'm not good at this whole map thing but i think that it would be just as nice to go to strahn for a driving trip. from devonport to shefield then down toward cradle mountain then after rosebury turn right to a wicked driving road that goes to a massive water resivor and then down the coast to strahn. Stay the night in a cabin and then go back up a different way or go down to hobart from strahn. Those 398kms are some very nice roads with some nice twists. then if you feel upto it go up the east coast back to devonport basically the same way you showed on your map. It should take about 3 days of good driving to do that but would be much fun... feel free to pm me if you have any queries i have driven most roads along the east and west. I havent been down south of hobart much though but i am sure that through the huon there are also nice roads..
https://www.sau.com.au/forums/topic/252999-roads/#findComment-4412503
this how I'd do it
http://maps.google.com/maps?f=d&source....515625&z=9
https://www.sau.com.au/forums/topic/252999-roads/#findComment-4412514
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
