I've got the thread saved, so I'll upload them all in this post.
I did this but didn't sit the bracket down properly, oops. Does anyone else have quite a loud pump noise when turning ignition to ON but not turning the car on just yet? Heh. All good.
^^Awesome
I was gonna upload some pics when i do mine, but no need now, i shall still take some though.
Just a question about the install. Once i have installed the fuel pump, i don't need to change anything else, such as pressure's, injector duty cycles, etc etc. It's just install and go?
If you're still running stock ECU/FPR/injectors, no, I'm pretty sure it's all sweet.
I'm having the Adaptronic ECU installed at the moment, and I don't think it needs to adjust... but when I upgrade my inj/fpr/turbo, I'll have to make modifications to the flowrate.
Any fuel hose should do, just make sure it is the right size.
I tried installing mine today...i failed miserably :D. I got the pump onto the bracket, but when i went to install the pump into the tank, it wouldn't go in, like it was too big or something. Could it have been because i hose clamped the pump to the bracket? the pictures above just show the fuel pump just hanging there, is that right?
I tried installing mine today...i failed miserably :). I got the pump onto the bracket, but when i went to install the pump into the tank, it wouldn't go in, like it was too big or something. Could it have been because i hose clamped the pump to the bracket? the pictures above just show the fuel pump just hanging there, is that right?
I used a metal ring clamp thingy to attach the pump to the bracket after cutting it, and it fits fine ;) Just gotta wiggle it around a bit.
And yeah, new fuel hose is good; just get stuff the same size, it's fair cheap.
Turns out I had a Walbro GSS 341 in there; now sitting here doing nothing :)
For wiring sake. Is the wire with the green stripe on it positive or negative? Im replacing the terminals now and forgot to take note of which way they went.
Thanks.
Likewise :) . The solid red cable is Positive (+), the red cable with line (grey/green, cant remember) is Negative (-).
Could i have a little help please fellas.
I am trying to do my pump again, and i am stuck as where to mount it.
Could you tell me from the following pictures, which way i need to mount it.
1
2
3
Last week when i tried, i tried doing in the same way as the third picture shows. Any help would be greatly appreciated, as my car is my daily, and i have work tomz.
I fitted mine the other week...only lasted about 500k's, the pipe i used was wrong and melted and the pump wasn't secured to the cradle. So the pump fell into the tank, and the car broke down, had to leave it in a maccas carpark for 2-3 days.
this is what i did...
Luckily my boss had installed a few of these before, he fitted it like you have shown. However i am only using 1 hose clamp (bottom one), i also got some new fuel hose from Autobarn. I also found that for me, the pump went in with the hose clamp tensioner/screw at the back of the cradle, so the opposite side to what you have.
  • 2 months later...
ok just wann know,
when mounted so low does this cause any issues like hitting the bottom of the tank as mentioned above?
and
Why are you guys not concerned about not using a filter/sock?
cheers
and while i am at it, these can be mounted in tank but these are "push" type pumps does this mean you gotta have 1/2 a tank to work/
and is anyone running these in tank without any surge tank setup
sorry about all the noob questions
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
