Hey all,
Seeing as im selling the car i will be parting out the wheels.
They are Genuine SSR SP1 2 piece wheels, black with a polished lip. They have plenty of dish and as seen from the photos, in my opinion they are sexy wheels. In addition to this they are fairly light, not that much heavier than the oem 18" alloys.
The wheels are in good condition, no buckles or cracks at all. However, there is small gutter rash about 2-3cm light on one of the rims due to the gf parking...Any wheel shop will be able to repair this for about $50-$100 if your really padantic about these things.
Specs of the wheels are
19x9.0 +11 Front 235/30/19 80% life
19x9.5 +5 Rear 275/35/19 (would need replacing unless you would like to swap them around)
I know this isnt the popular 19x9.5 +22, and 19x10.5 +22 setup alot of zed owners run but these wheels still sit the same way. If anything the fitment is almost spot on.
I get alot of compliments on the road from people with these wheels so be quick to grab this at a great price. Due to our crappy exchange rate expect to pay about $4500-$5000 for these rims.
Price:
$3300 Ono (incl tyres, red lug nuts, 15mm hubcentric spacer)
Western Sydney ( but i can post interstate at buyers expense using www.smartsend.com.au)
Contact:
0403337740 or PM
Edited by flyz33
https://www.sau.com.au/forums/topic/253177-syd-19-ssr-sp1-2-piece-wheels/
  • 3 weeks later...
would you take $2500 delivered to melbourne??cheers
Hey all,
Price:
Contact:
0403337740 or PM
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
