Hi All
Recently i picked up a r32gtr and after replacing the turbo that had a blown oil seal its been driving really well. Out of interest i decided i'd do a compression test on it and these were the results
120
130
130
130
125
130
Now i know these are a bit low for the motor but they seem relatively consistent and adding oil to the cylinders only upped compression by about 10-15psi. The car drives well and feels to have a reasonable amount of power. Any ideas why the low compression and will it cause me any major problems? It doesnt worry me too much as down the track if the motor starts to die i'll rebuild it but for now im more curious what the causes would be of the lower compression (just worn rings etc?) Maybe dodgy tester?
Cheers,
Rob
https://www.sau.com.au/forums/topic/253245-rb26-compression-results/
If the results are near enough to each other with minimal variance, then the motor is fine.
The results are a little low, but its a 15-20yr old motor. Its not going to be 160 across all cylinders and silly to realistically think they would be.
So basically the same as all the other compression test threads -
You didnt search, i can tell as this has been answered so so so many times now, with the same answer each time.
Here are some such threads going into the variance factor and the fact that your results are normal so there is no valid reason to question the results
http://www.skylinesaustralia.com/forums/He...mp;hl=comp+test
http://www.skylinesaustralia.com/forums/Co...mp;hl=comp+test
http://www.skylinesaustralia.com/forums/Wa...mp;hl=comp+test
There are plenty more threads on comp tests - have a search if your still feeling like the above are not enough
Thanks!
Guest
