Hi all,
Cleaning out the last of my R33 GTR parts and I have 2 sets of shocks for sale.
First off is the Sydney Kid R33 GTR kit. I had this in my R33 GTR for about 4000km, but the new owner of the car wanted the price lowered so this came out and in went an R34 setup instead. Spring rates are 4/3KG and are valved as per Sydney Kids group buy kit. Handles great as many will agree with.
Paid $1500 but will accept offers around $1000 and will negotiate/swap for parts and cash depending on what you have to offer.
The second set of bilsteins are of an unknown valving configuration. They are pretty firm but are re-buildable so for anyone wanting to make a custom set they are a cheap starting point. $150 ono.
Parts are located in Cairns, North Queensland. Will freight anywhere. PM or call me on 0434 147 478 if your interested.
Cheers,
Ian .
Hi all,
Cheers,
Ian Swinkels.
Are they Both off GTR's??
Yes indeed, both sets are R33 GTR, but also fit an R34 GTR and R34 GTT.
The setup pictured on the right is the sydney kid setup with the 4/3kg springs
The shocks on the left are the unknows that can be used as cores for a rebuild/custom dampner setup. No springs on this set though as you can see. When you go custom the springs need to match your valving anyway so you'd buy new springs to suit what you would have done to the shocks.
  • 4 weeks later...
  • 4 weeks later...
  • 3 weeks later...
  • 4 weeks later...
Are the Sydneykid Bilsteins valved for street or for track?
What are the differences between R32 and R33GTR Shocks? I notice the rear lower mount looks wider, are there any other differences?
Are they Sydneykids Eibach springs?
They are very streetable but work on the track as well (though I'd never done anything more than a motorkarna event with them in my previous R33 GTR). They were a huge improvement over my Teins that I had previously.
Yes they are eibach springs, 4/3Kg. I have no idea how they compare to an R32 GTR setup. Its possible the top hats just need changing to make them compatible but I dont really know and I dont have any means of comparison either... sorry.
Bump... and price drop.
Now accepting any reasonable offer and will also accept swaps of other skyline parts. Im building 2 engines at the moment and are chasing all sorts of parts so tell me what you've got and im sure we can work out a deal.
  • 1 month later...
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
