After a little advice & some knowledge from the SAU guru's.
Garrett GT30 Precision T3 turbo A/R.42 & EX.82
Compressor Housing stamped Garrett A/R.42 M24 EC-2
Compressor wheel 56trim 7-blade
4-bolt housing Exhaust wheel 11-blade,
Exhaust housing stamped Garrett 441326-016 M1 A/R 0.82
Rated to 525hp (?)
I gather I need an external wastegate, and a 4-bolt custom dump pipe 3" modifying my current JJR bellmouth dump/ront pipe
Any info about this turbo, expectations, how to mount and what sort of external wastgate to use and where to install ?
or can the rear housing be swapped out for an Internal Wastegate setup?
thoughts plx.. thanks.
this is for an auto RB25det, cams/head etc. to upgrade from Slide turbo
Pics hosted here for the time being:
( http://www.auctiva.com/hostedimages/showim...,0&format=0 )
http://www.turbobygarrett.com/turbobygarre...0382_12_new.pdf
https://www.sau.com.au/forums/topic/253353-garrett-precision-gt30-turbo/
how much is it?
you do realise that its only oil colled not water cooled?
the 2 links you have put up are for 2 completely different creatures.
the garret web site is a 3076
while the pic link is what looks like a journal bearing high flow with a 4 bolt rear.
the cost of waste gate, manifold, and dump mods will blow the changover out considerably.
Edited by dangerman4
From the pics that thing is weird , I'm not so sure that Garrett actually make a plain bearing GT30 based turbo .
The turbine being 11 bladed looks different from the 10 blade petrol spec GT30UHP .
The compressor housing looks more like a T3 sized one , T04B's are mostly 0.60 A/R though they do also do 0.50 and 0.70 A/R ones as well (Garrett that is) .
It's not some kind of Chinese copy of god knows what is it ?
A .
Yes being big on the exhaust side compared to the compressor end makes me thing it's aimed at some sort of large capacity low reving engine - Dieseasel .
In some ways it has similar traits to a GT3071R but without ball bearings and water cooling
, diesel spec turbine .
Some sort of bitzer turbo I think . Note ID tag is not a Garrett stamped one .
A .
  • 4 years later...
Dredged up old thread .
Viewers I stumbled across what looks like a plain bearing "Garrett" GT3067S turbo thats supposed to be standard on some great stall POS bus - um 4G180-20 diseasel engine . Anyway said to be a GT30 turbocharger and the cartridge looks like a big frame non water cooled plain bearing one .
Something of interest may be the single scroll IW turbine housing with a V band outlet and what looks like a T3 flange . Nowhere I looked showed the cartridge number .
I did find pics of Garrett boxes with all the details in dead spider lingo .
The only people who may be interested I reckon are those on the hunt for a plain bearing big shaft GT30 turbine and or that T3 flanged IW GT30 turbine houing in 0.82 or possibly 0.84 AR .
A .
out of interests sake - I ended up with a GT30 highflow from ATS Adelaide Turbo Services.
Garrett GT3076
part # 700177-5015
Internal wastegated ball bearing
with ported Nissan 45V4 front housing
AVO .73 6-bolt skyline rear housing
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
