Download "Utorrent"and install it.
Go to a torrent site (you may need to sign up).
I use www.isohunt.com as a torrent search engine. Open the torrent file with Utorrent choose the save location of the file and you are away.
the 'good' way is to purchase and download them through itunes.
otherwise that you can use a torrent search engine like isohunt.com or mininova.com, and download the torrent through a downloader like utorrent or bittorrent. Google it, there is a lot out there..
Does iTunes sell mp3's?
Excuse the ignorance as i thought it was just for fancy people with iPods.
If they do.. Whats the bps rate of them? 320?
Do they have literally everything or just alot?
beware of itunes, some head units refuse to play songs downloaded through itunes due to some reason that i can't remember at this time, but its stated on some of the specifications of certain HU's
remember people, download all you want, but the file must be deleted with 24hrs, its a promotional thing...
so their not mp3's?
I'd go with no, that said, there are other ways to dl music legally, i think its through bigpond you can do it, i don't know if you face the same issue though, never heard of the issue before with bigpond music
http://www.hymn-project.org/
This small program converts protected m4p or m4b audio files to either standard iTunes m4a files or, better again, mp3 files. It claims to convert the files without any loss in quality and the end result sounded pretty good to me.
thats correct slim
you can change it so when you import songs (i.e burn them to the cpu) they are imported as mp3 rather than the other.
But songs you buy from itunes aren't converted for some reason..
    • Just a thought, was that car and auto at any point of its life? If so, maybe whoever bridged the inhibitor switch/circuit did a not so good job.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
