hay i just left home to day to get a oil filter so i could change my oil and 2min's in to driving the car just started to run like shit missing cylinders all over the place and there was a lot of traffic so i just kept on going got the part and headed home and i tried keeping the revs low and that didn't work so i kept the revs high but not stupid between 3g and 4g and the problem went away. but i think that the ecu could be dumping fuel in to the motor and i think that makes sense because why else would it run fine in high revs. also my fuel economy was shit in low and high rpm
so i think i know what the problem is and now how do i fix it. need help asap because im going down to be racing my car next week
my car is a nissan skyline r33 gtst s2 auto
i was shitting my self there was a cop like 2 cars back almost all the was home and im seating on 1st and 2nd omg very lucky
i just cleaned my AFM with some AFM cleaner it cost like $25 biggest rip off
the car still runs like shit
i have to go to work now will be back working on the car in 5hr
i have checked all of my cooler piping taken it all apart and put it back 2gether and it still runs bad
i now think that the amf is sending the wrong signal or the ecu is sending the wrong signal
does any body know how to check that amf 2 see if it is working without trying somebody else amf because i dont know any body with a skyline
also how to reset the ecu and could this fix the problem ??
and any other ideas for trouble shooting would be much appreciated
im 90% that it is the o2 sensor that is shitting it self so i think i will replace that
because it runs the same when it is plugged in and when it is un plugged
also if u see a skyline in WA that sounds like it is about to die it is me
and the cops in WA ant 2 bad because i haven been puled over even with all of the engine problems
if you keep guessing what the issue is like this then we might as well lock this topic and forget it.
Why ask for help when your not prepared to do what we say ?
Try another AFM. then move on from there!!!!
cocky's! Why does everyone think that the O2 sensor is the be all and end all of problems with the way an engine runs? If you have a dud plug, for example, the O2 sensor, plugged in or not, isn't going to make a scrap of difference to how the engine runs.
i did replace the o2 sensor and the car still ran the same
i have no idea why my car ran the same with the o2 sensor in and when it was out with (the old one)
and then i went back 2 the spark-plugs i pulled them all out again and the one 3ed from the front was pissing out some milky crap and so i checked the oil and the coolant to see if it was a head gasket all clear and no other spark-plugs had this problem so i swapped the shit spark plug out for a old one that i know works until i have a chance to go out and get a new set because i have had it with these platinum ones im going to copper plugs.
well any why the car runs real good with the shit spark plug out maybe even better probs because of the o2
o and by the way "Guilt-Toy" i dont know any body with a amf so how do i test it what go and buy one. not every body has $$$ to throw around
and "blind_elk" u were 100% on the money but the car does run good with a new o2 no stuttering when i am idling so not a complete wast of time
thx for the help everybody i will post pix of the dud plug some time 2day
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
