WANTED TO BUY
Any R32 or R33 two or four door turbo in a damaged body condition for a project car. That is dings, dents, scratches, tears, faded paint, peeling paint, no paint, missing bumpers and the like. Stock mags or even steelies are fine.
Cars with structural damage i.e. bent chassis will not be considered.
Must be mechanically strong. That means engine, drivetrain, suspension. Exhaust can be a dodgy - will be one of the first things I replace. Tyres can be average I will definitely replace these as well.
Average kilometres is fine (150,000-ish) but will certainly consider anything with more or less.
Manual or Auto - I am unphased.
May also consider any other turbo import. I have particular preferences for Z31/32 300zx's, S13 Silvias, 180sx's, and Soarers.
This may be strange sounding given the previous list but would also consider a pre 1990 civic (I have a H22A that needs a new home).
I am located in Tasmania.
HOWEVER I WILL TRAVEL INTERSTATE FOR THE RIGHT VEHICLE!
The best way to contact me is probably via these boards (pm or post in this thread). Photos are a must, particularly for interstate cars, as I am busy with both a university summer course and work so we may as well not waste anyone's time.
Will consider virtually anything that doesn't have engine damage.
email any photos to: [email protected]
or post here.
Cheers,
Claye
https://www.sau.com.au/forums/topic/253726-wtb-r32-r33-gtst/
hi i have an r33 with side damage has recod engine with new parts plus spare engine and turbo has 19s on it and i have 16s plus veilside bodykit new un installed.car still starts and goes but is of course un road worthie
My 32 is still for sale, however if 33 tickles your fancy, I might have it for sale also.
Feel free to PM me for details/question, I'll happy to answer them.
Cheers
Grant
Got a r32 gtst gunmetal grey body not the best but mechanicals a1.
Mods as follows
engine new rings bearings and gaskets
cometic head gasket
hks 25/30 turbo
full hks super dragger exhaust with aftermarket dump pipe
hks pod
hks bov
cooling pro fmic
gtr injectors
blitz ecu
adjustable boost
exedy heavy duty clutch
list goes on, if u r interested will send pics
PM sent.
I am looking at local cars and have found something very interesting. So if you have anything nows the time to tell me, otherwise monday I will be parting with some cash (most likely).
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
