ok i went 2 cop stn this arvo. they said i cant write a letter of everything that happened and put a copy of the fine with it. send it to this place, they'll review it, put it on hold and see where it goes from there. if they see i wasnt in the wrong im all good if not i can go 2 court. when i told him i had only just been over speed bump and not even 20m later i get pulled over for doin 72km in 50 zone he looked surprised. then when i said that the cop was tailgatin me he said oh definatly put this letter in. so fingers crossed
basically say you were trying to evade a tailgater and get out of their way or out of fear. I've been advised of ppl being followed for the purpose of stealing their car so it's not such a far fetched idea that this happens.
They ask you about the previous few years when first getting the policy but not after that, nothing mentioned in the policy handbook anyway.
Pretty sure they say that YOU have to make them aware of any further infringements, the onus is on YOU to make sure THEY are aware of your driving record. Maybe it only applies for serious offences.
as u suggested its usually only meant for accidents that were ur fault or loss of licence etc etc.
not for getting dermit points... for example going 12kmh over the limit and getting 1 dermit point.
Edited by br3ndan
TBH I don't really care, but I think before any of you take anything for granted, you should call your insurance company and find out.
I was only stating what *I* was told in an effort to stop anyone getting taken for a ride by an insurance company trying to weasel out of a claim.
generally when they try to weasel out of a claim of say 4-6k just keep bugging them about it and say youll take it to court. Generally it's cheaper for the insurance company just to pay you out, I know this firsthand and if you'd like anything answered by someone who works in the industry you can pm me. (I don't work in the industry, someone close to me does and isnt just a ground level chump either)
  • 3 weeks later...
you can say you had to spped up to avoid having an accident, this does work in some cases ie passing a red light because person behind you was sticking wright to your bumper. all you have to do is explain the cop was travelling dangerously close to your car (not slowing down for speed bumps) so you tryed to avoid the dangours driver as he was to close for you to attempt to pull over and let him pass. the wost that can happen is you still get your fine but if the cop does this several times evetually court will have to let people off.
one of the best things we could do as a motor enthusiast group is to keep a forum open to names and action of dangour cop driving and thing they do to unlawfuly to take are point eventully if someone name comes up a few times it can be used as evidence and i know this has been done to cops who pick on groups of people.
p.s what a f**kign wanker
I somewhat doubt that "I had to SPEED up to AVOID an accident" would hold up in court very well, but I very well could be wrong never been a situation like this.
Anyway how did this situtation go, get a court summon yet and what not?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
