My 1997 series 1 RS4T has frontal damage but most parts available. I guess only bits that can be posted will be of interest to Australian members (car is in Auckland NZ) but if someone is really keen I can get a price for freighting the auto trans (price AU$350 for the box).
https://www.sau.com.au/forums/topic/254086-wrecking-silver-s1-rs4t/
hey dude,have you got the passenger side wind protecter thing?
cheers
rodney
cheers
rodney
Yep, managed to get it off in one piece...it's just held on by a few clips and then double sided tape or glue. Its very long 1800mm - I'll get a price from the post office tomorrow. I reckon about $100 incl postage but I'll confirm tomorrow - how does that sound?
ps anyone want the driver's side?
yeah no worries matey,let me know how you go
RS Four badge off grill $20 delivered anywhere in NZ or Australia. Someone was looking for badges a while back. can't sell the back one because I am looking to sell tailgate complete.
if the bolts that hold your calipers to the hub are 22MM plz PM me, i need one.
Cheers
Ryan
Bolts are 45mm long (excluding head) and 14mm dia for fronts.
Hi rob,
Dont have a rear spoiler by anychance? If so how much posted to 5066 south australia. :D
Cheers.
Sorry just sold the tailgate complete with spoiler
22mm bolt head?(holding caliper frame too the hub)
also do you have the screw in trim bits that sit near the tailgate for the privacy screen to attach too?
also rear cupholders? mine broke :sick:
How much for the right hand side wheel gaurd? The black plastic bit that protects the area between the front bar and wraps around to the other side of the rhs wheel? Postage to Brisbane.
Sorry totally destroyed by impact
also rear cupholders? mine broke :P
all gone but I 'll shoot down to my mechanic tomorow - he's got one to wreck as well
also broke my fronts today >_< fkn long legs 1/4 cupholders still in one peice lol
also broke my fronts today :( fkn long legs 1/4 cupholders still in one peice lol
Can do the front cupholders. I'll see what else I can find to save on postage. Let you know soon.
Drivers airbag?
THis is a joke? Wrote the car off after hitting a culvert after running off the road - airbags and seatbelts saved my life - they won't be much good to you.
I do believe I need the driver's side for my Series 1. Price inc postage? Still $80?
:) Post first, read later!
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
