  • Replies 45
my spool is fitted very happy with it almost half the weight of the oem centre yet it looks indestructable
gearbox is a powerglide
and the doors are being made in 100% carbon fibre should be ready in may (being made locally brisbane)
how long till your car hits the track???
Edited by jas/slo32
https://www.sau.com.au/forums/topic/254206-slo32/page/2/#findComment-4515214
and the doors are being made in 100% carbon fibre should be ready in may (being made locally brisbane)....
that sounds great.....can you post up the weight with windows when you get them back? Would love to know how our lightened std route compares to full CF
https://www.sau.com.au/forums/topic/254206-slo32/page/2/#findComment-4527293
Havent got the doors yet but did take the car to the weighbridge on the weekend @ race weight full fuel oil etc
car 1130kg raceweight
car with driver 1210kg
im hoping with carbon doors/bonnet/boot to get the car just under 1100kg but 30kg is alot of weight
https://www.sau.com.au/forums/topic/254206-slo32/page/2/#findComment-4538274
  • 5 months later...
Car will be for sale shortly with new engine 0 hours use
details
engine
rb26/30
grout filled block
nitrided crank
cp pistons
argo rods
arp rb26 head studs
hks 272 cams
arp bottom end studs
acl race bearings
jun oil pump
ati 1000hp balancer
ati dry sump drive (for fuel pump)
hks manifold exh
garrett gt42r
custom plenum with 100mm t/b
1800hp belt driven fuel pump/reg
12x 1600cc injectors
electrics
motec m8oo
msd dis 4
motec coils
6x egts
5 bar map sensor
all new wiring
driveline
2spd powerglide checked over rescently
new 6000rpm converter & vasco input shaft
1pc tailshaft
diff
gtr rear end
new full spool centre
new bearings
heims joint adj toe arms
body lightweight
as per previous post
gtr front guards
lexan windows
frp bonnet
frp headlights
current tech
minitubbed
parachute
14lt fuel cell
4lt catch tank
wheels
new 15x8 billett rear
new 15x3.5 billett rear
26x4 front
28x10 rear
price $40 000 ono with car trailer pm for more details
or ring 0424348521
Jason
Edited by jas/slo32
https://www.sau.com.au/forums/topic/254206-slo32/page/2/#findComment-4848287
  • 1 year later...
  • 3 weeks later...
  • 3 weeks later...
  • 4 weeks later...
Car is now for sale as a roller minus engine,trans,tailshaft,ecu,cdi & rego plates.
Weighs 1179kg race weight with 90kg driver
car drives straight,current tech,6 point cage etc etc
$10k ono need to make way for chassis car
Phone Jason 0429232288
located bundaberg qld
https://www.sau.com.au/forums/topic/254206-slo32/page/2/#findComment-6128763
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
