A chance has arisen to buy a very special car (still a skyline) very soon so im just seeing if it will be worth selling this one
Looking for around 19 for it
Im well aware that cars are not selling in this awesome climate but putting it out there anyway ;)
specs 1990 gtr 96,000 klm's – mines 320 klm dash
dark blue
Gearbox good - i dont thrash it
Greddy timing belt - changed 1000 klm ago including New tensioners etc
New water pump - 1000 klm's ago
New Splitfire coils - brand new installed 1 month ago
Plugs - new
New tein street specs - brand new installed last week
New head unit - basic x-plod
New garret Garrett GT2860R-5 - brand new installed last week !
New stainless manifolds
ARC - Titanium radiator air deflector
Brand new - Kakimoto Regu 06&R Exhaust - Nissan Skyline BNR32
Brand new front pipe
Brand new 3 inch dumps
All new exhaust and turbo studs
New greddy gear knob
Brand new engine and gearbox mounts – yet to be installed
Apexi air pod kit – 2 months old
Royal purple oil used in engine
some pics of the recent turbo swap
grabbed some purple as well
brad had to take some meat from the turbine housings to match to the new manifolds
as you can see below a fair bit had to go
installing the new studs
dumps joined
manifolds attached
Edited by DAS KAMU
https://www.sau.com.au/forums/topic/254208-eoi-1990-gtr/
  • 3 months later...
  • 1 month later...
  • 4 months later...
  • 3 weeks later...
  • 2 months later...
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
