A chance has arisen to buy a very special car (still a skyline) very soon so im just seeing if it will be worth selling this one
Looking for around 19 for it
Im well aware that cars are not selling in this awesome climate but putting it out there anyway ;)
specs 1990 gtr 96,000 klm's – mines 320 klm dash
dark blue
Gearbox good - i dont thrash it
Greddy timing belt - changed 1000 klm ago including New tensioners etc
New water pump - 1000 klm's ago
New Splitfire coils - brand new installed 1 month ago
Plugs - new
New tein street specs - brand new installed last week
New head unit - basic x-plod
New garret Garrett GT2860R-5 - brand new installed last week !
New stainless manifolds
ARC - Titanium radiator air deflector
Brand new - Kakimoto Regu 06&R Exhaust - Nissan Skyline BNR32
Brand new front pipe
Brand new 3 inch dumps
All new exhaust and turbo studs
New greddy gear knob
Brand new engine and gearbox mounts – yet to be installed
Apexi air pod kit – 2 months old
Royal purple oil used in engine
some pics of the recent turbo swap
grabbed some purple as well
brad had to take some meat from the turbine housings to match to the new manifolds
as you can see below a fair bit had to go
installing the new studs
dumps joined
manifolds attached
Edited by DAS KAMU
https://www.sau.com.au/forums/topic/254208-eoi-1990-gtr/
  • 3 months later...
  • 1 month later...
  • 4 months later...
  • 3 weeks later...
  • 2 months later...
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
