Im looking at possibly selling my car if i get a reasonable offer. I may even swap with a cash adjustment.
Will post a recent pic and dyno sheet up soon.
Here is a list of mods:
Engine:
(Brand New engine installed on Friday. Just run in over the weekend.)
Wiseco forged pistons (Bored out .40 thou)
Shot peened rods
ARP rod bolts
Grounded & Balanced crank
New rings, bearings, oil pump and water pump.
New head with new valves, seals and lifters.
Copper head gasket
O ringed head and block
Garret GT35/40R turbo (700hp) - OLD Turbo. Now fitted with Trust T88-33D
Custom exhaust manifold
42mm Wastegate
Moddified plenum
660cc injectors (Brand new, been in the car for 1 week)
Micks Metal Craft frountmount cooler
Oil catch can
MSD ignition
Microtech computer
Blitz blow off valve
Surge Tank
Copper fuel lines
700hp Bosch Motorsport Fuel pump (Brand New)
Drive Train:
Rebuilt strengthend gearbox
Brand new clutch, flywheel & pressure plate
2 way LSD diff
Suspenison & wheels:
Tein Adjustable coil overs
Poly Urethane bushes
18in 3 Piece Zepters
18x235x40 front (brand new tyres)
18x265x35 rear (brand new tyres)
Exterior & Interior
GTR body kit
Resprayed in White with Purple Pearl
WRX bucket seats
Blitz Dual SBC - Boost Controller
HKS turbo timer
Pioneer stereo and stacker
Alarm with immobaliser
Sunroof (No leaks)
Tinted Windows.
Many more mods. Can provide receipts.
Car is located in Brisbane. I am contactable on 0410 553 070.
Thanks
Harun
"True, but not 25k. If you find another skyline with the same specs as mine, in the same condition with a brand new engine and so forth. I will burn my car and take photo's of it too."
me thinks ur all talk
lol!
free bump
actually there was a series 2 R33 up here pushing the same hp at the wheels and it sold for very close to 25k :P
BURN BABY BURN!
na only jokin. it didnt have as much work done but it could get a 11.7 on slicks. i guess it had the power to go faster
Man it breaks my heart to hear of people selling cars with this much work for under 50K
I have already spend 30k on mine (just over actually), as I bought it stock. I havent even rebuilt the engine yet, as I dont have a spare 8k lying around. Even then, I have had to shop far and wide to get bits at good prices, which aint easy.
Why are you doing this, seriously - I just cant understand how you can pour so much money into a car and then sell it, and so cheaply
Some ball park conservative figures
Wheels $2.5k+
Cooler (and pipes) $1.1k (then fitting)
wastegate $500
Turbo $2.5k
ECU $1.8k (then the tune and install)
diff 800+
Clutch 1k
EBC $500
Manifold $1k+
Plenum??
Fuel pump and surge tank $500 (not including the fuel lines)
Injectors $1k+
Catch can $200
BOV $200
Engine build 8k+
Body kit fitted and paint (with compelete respray) 2.5-3k min
Sus 1.2k+
stereo 1k
alarm 200
MSD $800
seats $500+
turbo timer $100
rebuilt box $????
tint $300.
Dude thats 30 000 dollars in mods, and the above prices are pretty conservative, and mostly dont include labour.
I am sure like most cars there are dozens of other little things that all add up and when you consider the cost of labour - how many people really appreciate that it costs 1k to remove and fit an engine for a build, or $200 to fit sus, about the same to fit a clutch. Tune ups cost 3-600 a go.
WHAT ARE YOU DOING?????? this really kills me. (sell me your diff please:D)
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
