Hey, My R32 GTST came with one of those add on things that go over the top of the Word skyline which makes it light up (blue or green)
Does anyone know anything about them...i really wanna connect it and i heard that ya have to have some special relay or something
I also heard that they were an optional extra when buying a skyline new...and u could select either Green or blue
Is it just better to buy a small neon or getting the right relay...or simply connecting it up again???
Thanks!
Originally posted by chaos
or yeh set up a neon behind it
I could just buy some of that flexi neon stuff...but i wanna see what its like with the propper lights in it...i think it reflects the chrome part or soemthing...ill pull it apart one day and check it all out
I wonder if i just somehow i find away to connect it up...maybe it will work
i heard that u can connect ur break lights so the reflect into the skyline part to light it  up but not sure exactly
Damn that would be cool...I WANNA DO THAT!!!....imagine having it glow blue then as u break it turns red....would have to have a seprate red light which is jumped off of the break lights...is that possible???
Anyone know how to do this????
Where there is a will there is a way i sopose
anything is possible really
what you could possibly do is place mirrors in there so that it reflects the red through the word when u break and when u dont it shines back to blue or whatever colour you want
you would need some sort of kill switch to cut the current when u press the brakes so that the blue turns off
I've got the blue/green ricey "SKYLINE" on my 33. I had the car for two weeks before someone else pointed it out !! You gotta scrape the mylar foil off the lettering (ie remove the panel) light goes in behind, wired to GND and switched thru taillights, hey presto you're the son of rajab Of The Rice ( one rice to rule them all).
Personally I reckon it would be quite a mission, but I guess it looks cool enuff to some folks to warrant the effort.
hope this helps.
It's definitely aftermarket, 'cos the Jap who installed it didn't scrape off all the mylar, & just twisted bare wires together & wrapped a bit of masking tape around the whole lot....dodgey !!
hmm unsure of that one...i guess if u put neons behind it and have them so u cant see the direct light and only the glow..then should be all good
Should be fine as well with the glowing off the chrome...but who knows
Me too! me too!! i want one.. may seem ricey to some, but its a factory optional extra.. and i just want it! Does anybody have one? which cars normally have it? How can you tell if it has is the illuminated one? will have to go to jap wreckers and hunt around.. Oh, i dont see how it could be illegal, its a factory optional extra...
U will know if u have one cos it is a stick on plastic thing...at the moment i have mine in bits...cos the acual factory light blew up...probably cos i found it full of water...and im currently trying to put neons in it...i have those flexi EL wire ones but the glow isnt bright enough...i mught just get blue perspec's and put lots of LED's in it insteed...will look cool when finnished...hopefully!!!
U will be lucky if u can find one cos to fit it u need to drill holes into the existing bumper and they use a Sh!tload of glue crap...and its impossible to not rip paint off when taking the glue off...ill hopefully post a pic when i have finnished mine
    • I normally run with I think a 10mm, and definitely use the second handle you can add to a drill. They hurt when they bins up!   For the crush tube, once all subframe is clear, I'd try some stilsons and see if I can get it to start to twist.
    • Probably because they couldn't, because the use of the variable resistor to create a "signal" in the ECU is managed by the ECU's circuitry. The only way that VDO could do it would be if they made a "smart" sensor that directly created the 0-5V signal itself. And that takes us back to the beginning. Well, in that case, you could do the crude digital (ie, binary, on or off) input that I mentioned before, to at least put a marker on the trace. If you pressed the button only at a series of known integer temperatures, say every 2°C from the start of your range of interest up to whatever you can manage, and you know what temperature the first press was at, then you'd have the voltage marked for all of those temperatures. And you can have more than one shot at it too. You can set the car up to get the oil hot (bypass oil coolers, mask off the air flow to oil coolers, and/or the radiator, to get the whole engine a bit hotter, then give it a bit of curry to get some measurements up near the top of the range.   On the subject of the formula for the data you provided, I did something different to Matt's approach, and got a slightly different linear formula, being Temp = -22.45*V + 118.32. Just a curve fit from Excel using all the points, instead of just throwing it through 2 points. A little more accurate, but not drastically different. Rsquared is only 0.9955 though, which is good but not great. If you could use higher order polynomials in the thingo, then a quadratic fit gives an excellent Rsquared of 0.9994. Temp = 2.1059*V^2 - 34.13*V + 133.27. The funny thing is, though, that I'd probably trust the linear fit more for extrapolation beyond the provided data. The quadratic might get a bit squirrely. Hang on, I'll use the formulae to extend the plots.... It's really big so you can see all the lines. I might have to say that I think I really still prefer the quadratic fit. It looks like the linear fit overstates the temperature in the middle of the input range, and would pretty solidly understate what the likely shape of the real curve would say at both ends.
    • I got a hand held bisssel one and it's a piece of shit. Doesn't work for more than about 5 seconds. So much so that I nearly refuse to believe any wet dry vac actually works or has enough suction to clean the carpet of a car. I'm discouraged as all the good ones are $300+ for an unknown result. I saw MCM did a Ryobi video where they use this thing: https://www.ryobi.com.au/products/stick-vacuum-cleaners/18v-one-hptm-brushless-spot-cleaner-tool-only Anyone have any experience actually using a tool like this when not paid to showcase it?
    • That could very well be the thermistor, but the ECU only sees Volts. VDO don't seem to provide a 0-5 volt curve, only the resistance curve.... (or line).
    • Yes. Probably, given that there is only access from the bottom end of it, go with a drill bit. Don't start too small. 7 or 8mm is probably the right size. You want something that can make a big enough hole to do some damage, but not so bit that it clashes with the steel or binds up and breaks your wrist. A slow speed is probably a good idea too. Once the rubber is destroyed, you then have to get the crush tube off the stud, which will be the whole heat/oil/cutting exercise all over again, but this time with the need to strictly avoid damaging the stud (any further than the corrosion might already have done.
