just head to auto perfection/installer of choice, grab a decent aus standards alarm and have it backed up with a few hidden killswitches that automatically become active when the engine shuts down.
... and get a bit f**k off club lock.
https://www.sau.com.au/forums/topic/254407-alarms/#findComment-4392336
consider a gps tracker, retail around $350 and all you need is a sim card that sms's you if the car has:
1. moved from your pre-set perimeter
2. alarm gone off
3. engine been started
+ lots more
and best of all in case its on the move while you're sitting at your office desk, it sends you the cars current global position + speed etc...
on top of all that it makes the job of recovering a car easy as for the 5.0
https://www.sau.com.au/forums/topic/254407-alarms/#findComment-4392406
Adam:
Go see Ric at Auto Perfection. He fitted an Aust Standards alarm to my legnum that has been great so far. Never had false alarm, but has been set off (unintentially) so I know it works too. Also, tell him your from SAU and you'll get discount too thanks to Steve (Madaz)
https://www.sau.com.au/forums/topic/254407-alarms/#findComment-4392522
yep... thanx to sled and nightcrawler for letting me go :( it was just intended to see whats out there not a i have this kinda thing.... any one had problems with auto watch, viper, cheater all of those kinda people?
im after sumthing with a few imobeliser points
seperate control buttons as ive got a nismo key so if i lost the orig key id b stuffed
i have a gps tracker elsware
turbo timers are bling... but seriously r they worth the $
paging hand peice would be kool but DO THEY WORK LIKE THEY SAY???
https://www.sau.com.au/forums/topic/254407-alarms/#findComment-4392528
turbo timers are only useful for people who really boost heaps... think mallala.... most of the time 30 seconds cooldown is all you need and that you can do while collecting your wallet, getting out of the car etc...
-D
https://www.sau.com.au/forums/topic/254407-alarms/#findComment-4392696
+1 to GT Autosound.
And yeah, wouldn't bother with a turbo timer... just search Turbo Timer on SAU and you'll get the same answer.
I quote from the Nissan Skyline owners Manual: "If you've been driving for a extended period over 80kmph, when you reach your destination, let your engine idle in neutral for 15 - 30 seconds".
Meaning, if you've been flogging your car and testing to see if you can actually reach that 320km/h mark on your Nismo speedo, let your car cool down after!
https://www.sau.com.au/forums/topic/254407-alarms/#findComment-4392783
no probs Adam....seems to be going well so far
here's one thing though....please nobody post the short comings of any particular brand, that may give clues on how to get around that particular system.......that will be the doom of this thread.
https://www.sau.com.au/forums/topic/254407-alarms/#findComment-4392840
Adam, generally speaking:
Paging System-styled alarms - Work well in a close radius. Won't work well 'deep' indoors or over long distances. Meaning, you'll receive the signal/notification when you get back into range. Good feature to have, though.
Just make sure you get a Aussie-standard alarm system with all the usual goods. And get it installed properly the first time.
And, don't be stupid and stick up "This car is protected by xxxxx alarm system" stickers on your car window!! You'd be amazed by the sheer amount of cars that have this! It's basically advertising what alarm you have installed, making it alot easier for people! Example: "Oh, he has xxxx alarm installed... that means I can do this xxxxxxx to get in!"
https://www.sau.com.au/forums/topic/254407-alarms/#findComment-4392903
Myself and jack 88 can speak of alarms and audio, I owned/worked in a auto audio and alarm shop/home theatre in USA for 15 years and hold a master installer certificate in auto electronics. as well as Aviation advance electronics
I can say , stay away form the cheap alarms(ebay specials, not covered by warranties ), stay with something from Direct electronics , Clifford, or one of the local major brands , makes sure the connections are soldered , no other connections are acceptable, black taped into the harness to look factory.and properly fused, and power from multiple sources. , pin switch on the bonnet, boot, back up battery , a GPS if you can afford it? or a paging alarm , the new ones work for a few K away, even in stores at the mall, depending on the metal and antenna placement. the alarm LED needs to be seen BEFORE the window gets broken?
a field sensor is good if setup right? of course a shock sensor that is setup and tested on install, then a few weeks later after the wires settle in, a free check up is a must. the sensors shock sensitivity changes sometimes so make sure its free to reset a week or so down the track.
crims setoff your alarm over and over until you get sick of it and shut off the alarm completely. so dont fall for it!!!!
a 3 point system is recommended, but no matter what brand you get, its only as good as the install, and must be used everytime you stop, even in front of your house for 2 seconds. and even a shit club lock on top of the alarms delays and deters the thief to move on to other cars.
the fuctions you get added , like windows, door locks, timers, sunroof etc can rack up the install cost fast, so be warned. the timers are defectable if hooked up. so dont place the sticker it comes with on the car , it alerts the cops to the turbo timer. besides just sit in the car for 30 seconds instead.
you might think too much security is a pain but when you come out to a empty car park,,,, you will change your tune? or a pile of broken glass ???
prices range a lot in town and people do haggle on items like this. so HAGGLE!! I cant recommend a shop , maybe GT autosound or MOB because I install all my own stuff .
and two remotes are a bonus, cause if you loose or destroy one, they can be expensive to get one afterwards. some 200ea.
they must come with a lifetime warranty on install and electronics, no extra gimmick charges for that either. a good installer has no worries about it working for life of the car ownership.and proud of his or her work to let you see the process on another car. alarm just tossed behind the dash take seconds to bypass, make sure its mounted well out of sight and secure. the siren needs to be near the firewall, not near the cooling fans. no wires should be visible at all???
and if you fidle with the wires it wil void the warranty they can tell it you have !!! dont do it!!
alarms are about DETERING the thief BEFORE break ins, and then about using as many ways possible to stop a crim if they break in.
understand a professional car thief will get your car no matter what you do to stop them, if they want it,,, its gone. a GPS is the only hope if used the second it detects the car is stolen.
good thing most arent pro's , most just want a thrash and burn,(joy ride) or strip your parts off and dump the rest.
and dont expect a alarm to stop someone from breaking your window out if you leave items in plain view, the temptation is too great for crims.
and the sticker they come with are a mixed bag, if you buy a good alarm advertising it will stop crims, but average ones dont bother it says steal me Im easy target. I have never seen a car with brand stickers broken into unless it has stuff out in the open , a cheap alarm, or the alarm wasn't on. which by the way voids your car insurance payout too. but know of surveys with crim , they will steer clear of cars showing a serious alarm setup.
my two cents , feel free to ask away
Edited by sapphiregraphics
https://www.sau.com.au/forums/topic/254407-alarms/#findComment-4393125
my alarm has a red led that doesnt flash very bright, even at night. any way i can run a bright secondary light to the corner of the windscreen?
yes very easy to do, but watch out the load on the alarm brain cant be exceeded or it will fry.
the current load will increase by 2 and most LED will be duller then, so you need to have it done properly. also some LED lights have a narrow field of view so watch out for that too..?
you can also buy a better LED, or change colours, or scanners or just about anything you can imagine. a 555 timer(silicone chip) will run multiple lights on the Brain power output. for a few bucks, a good look is to mount them on the A pillars on both sides, or on cars with door locks showing , drill them and place the led in the outside layer of lock pin, or even in outer door handles near lock covers or mirror pods. just takes time to do . not expensive. but extreme care has to be used.
a new brighter LED is under 5 bucks , takes a few min to install. but check the power output, a resistor is needed on most LED setups. output voltage varies, from 2-12 volts output. and a 1 amp fuse is a worthwhile investment on the line to LED's just in case it shorts out
https://www.sau.com.au/forums/topic/254407-alarms/#findComment-4393163
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
