Hi All,
My car currently has the AVO Stealth Front mount that uses the standard pipes (came with my car when i bought it). The cooler is 295x460x90mm Core. More info below but nothing on how much power it can flow.
http://www.avoturbo.com/avoshop/product_in...products_id=241
I have an R33 S2, am upgrading my turbo soon, should be looking at 260-270rwkw.
Will this intercooler be big enough? Will the stock piping be ok?
https://www.sau.com.au/forums/topic/254444-will-my-intercooler-be-big-enough/
Pretty sure they measure them by how much boost they can take not by how much power.. Obviously you will want to make sure it can flow the air too but it will be plenty big enough piping for that air flow. If my cheap shit chinese core can take 35psi or something round there then your one will take enough boost to make 270 easy.
Some one correct me if im wrong though..
Good luck :yes:
AVO make some very high quality stuff mate..
that cooler will be plenty for your power requirements.
the other things is this.
the usual ebay coolers are 600 x 300 x 75
If you calculate the volume within each cooler, there is not that much difference..
And the avo cooler is going to have a much better designed core.
yeah mate, the cooler came with the car, but someone definately forked out the big bucks to pay for it. I looked to see how much they are, and they are around 3 times the price of some basic coolers.
PLus its black and no one can see it unless they are right next to it.
Thanks for the tips dude.
bit of useless information (well i found it interesting) the PWR intercoolers flow approx 30% better than the Hybrid branded intercooler... and when i say FLOW I'm referring to the air flow which cools the air going into the plenum and not the air going inside the intercooler.
even if this figure is made up by pwr fanboys, what would be the reason for the difference? ie. what are the factors about the core which affects this and what could i look for without just letting somone make up a figure?
Liz.
Its a game between the flow to cool, and the flow to the motor.
Each core design is different and some flow more past the fins and cool better
Some flow more to the motor and cool less
Its finding a core that is the best between the two that matters.
If you measured inlet temps with both those coolers, that would have been perfect to decide :)
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
