Anyone know the legalities of bringing this over from VIC to be registered in SA?
i can look into it for you, ill try get to it this weekend if i can
maybe try the vicroads website?
cheers
jarryd
  • 3 weeks later...
  • Replies 43
Posted Images
just an update, i have a temporary mobile number:
0427 082 930
plz dont ring the other number.
as i said this is only temporary, will advise when a new number is issued.
cheers
jarryd
Hi, I'm pretty interested in this car for my gf. I'm also wondering about getting it reg'd in SA, but I'll try and find out what's required from our Rego place this week. Would you be able to get an RAA inspection or similar before we flew over there to take a look? Were you the first owner of this car in Australia?
hey mate.
i work at a fairly large car dealership and i can get my work to get a RWC check done for you if you are genuinely keen on it.
I know for sure it needs a windscreen because i just had a rock hit me last week unfortunately.
i am the second owner of this vehicle in australia. the previous owner privately imported it himself from japan with only 24,000-ish-kms on it in 2004, and i bought it off him in April 2006 with 75,000-ish-kms on it. the car now has 112,000kms.
as in regards to getting it rego'd in SA, i would have to hand the plates in here in VIC, and you get a permit to drive it from VIC to SA.
hope this helps at all
if you have anymore questions please dont hesitate to contact me. i am not on here much at all anymore, so maybe send me an email to my hotmail account, or you can shoot me an SMS anytime.
cheers, hope to here from you soon.
Jarryd.
Hey bud, would you be interested in parting with the Stagea mats.
I got jibbed when I bought mine.
PM me back.
Cheers jason
Bump on a very tidy S1.
PM me back.
Cheers jason
no thanks, sorry.
also, price drop 11k, no RWC.
cheers
jarryd.
  • 3 weeks later...
  • 3 weeks later...
Hey everyone, :banana: ill make a proper intro soon coz i plan to be a good member to this forum but OMG! I seen your car on carsales mate, Looks nice. Im very interested in your car but i am in the process of selling my car so i cant even look at it... dont wanna get my hopes up and all. But as sson as that happens... expect a phone call lol :banana:
cheers mate, thanks for the comments.
price update:
$10,300, with the rego till april next year, NO RWC. it does need a windscreen.
for an extra $200 i will throw in the Apexi SITC
also for whatever price it sells for, it will come with the stock 16" wheels (no tyres) and the stock muffler.
cheers,
Jarryd.
its cracked, a rock hit the base of the screen where the wipers are, and it goes into like a U shape. i was doing 100 km/h on the freeway and i was following a truck, and im lucky it didnt hit me in my line of sight.
i have dropped the price accordingly, and if the buyer is genuine i may be a little bit more negotiable on price.
have been quoted $400 for a new screen.
cheers
Jarryd.
seats are in near perfect condition, only a scuff on the drivers side seat where your hip would be, where u get in and out.
was there when i bought it.
ever since ive had the car the seat covers have only been taken off maybe 3 times.
rear seats hardly get used as well..
cheers
jarryd.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
