Hi all
I am at my wits end to solve this problem ive had with squealing brakes. Im running QFM D1RM pads on DBA 4000 slotted rotors. Rotors were brand spankers when pads went on.
I have tried:
With shims
Without Shims
With shims and CRC Red anti squeal glue between the shim and the pads backing plate.
Without shims and the anti squeal glue between the calliper and the pad
Using the glue to glue in all parts - The pins, the spring and the saftey pin to stop them from vibrating
I also tried the above with a loctite substance on the recommendation of the seller of these pads, again, no effect.
I have also extensively cleaned the rotors, calipers and surrounding parts to remove dust build ups.
After none of this worked, I got more aggressive. I compared the profile of the pad to a Bendix ultimate pad and noticed the ultimate had sloped edges. I used sand paper to rough up the top of the pad then wear away the edges so they were slanted, then went and bedded the brakes back in. This seems to have somewhat reduced the effect but its still quite strong.
im now completely out of ideas. Any assistance I could get would be great. This is ruining the whole driving experience for me as I am afraid to touch the brakes for fear of drawing massive amounts of attention to myself. The pads I use are supposed to be quiet and not squeal and have had tons of good reviews, and I have seen them used in other cars with excellent results. Their performance is awesome with lots of bight and no fade but the noise is unbearable.
Help?
https://www.sau.com.au/forums/topic/254897-squealing-breaks/
Mate, i am in the same boat as you, i have been told that if you do not grease up your caliper bolts then the caliper can f**k up and cause squealing.
ATM i have 2 rounded wheel nuts on the side thats making so much noise so i havent had a chance to test this out but once i have i will re post with my findings.
Good luck mate, i know EXACTLY how it feels.
Greasing up the caliper bolts? Haven't heard of that before.....
Me either (for squealing). AFAIK greasing bolts is done to ensure that bolt tension is the most accurate when combined with a torque wrench, because it creates a predictable level of friction between the thread mating surfaces. You use a lower torque setting for greased vs dry but end up with the same level of bolt tension. When i installed my brake upgrade kit UAS told me to use the thread lube stuff. For a lot of stuff its not worth worrying about, but for flywheel bolts (and i guess calliper bolts) etc its important.
The research i did suggested that the squealing is caused by vibration between the calliper piston and pad.
FWIW, my old setup with the stock callipers was; pad backing plate -> shim -> shim grease -> shim -> red goo -> calliper piston, and I had no noise at all. I never worried that much about special bedding in procedures (but that doesnt mean you shouldnt).
By calliper bolts do you mean the two bolts that old the callipers on? Should I grease them up? Ive just dont them up as tight as i can, I was thinking of loctiting them in with a soft threadlocker.
Or do you mean the two bolts that go through the pads to hold them in place? If this is the case, what grease should I use? I tried coating them in the CRC red stuff and this seemed to help for a while but the effect soon returned.
To bed in, I used rough sand paper to rough up the top of the pad then I basically did 6 - 8 100 - 20 or so stops and a few 60 - 0 stops in a local back street however I didnt want to annoy too many people so I left it at that, the brakes were squealing rather badly and the car is not quiet by any means.
Correction, grease up the caliper slide pins.
ATM i have bendix standards in my car and i have feeling they could be the culprit, although its weird that bendix standards would squeak.
I have bought CRC de-squeak and sprayed my front rotors, this has helped a little bit but the squeal still comes back but not as bad.
Nissan pads are the go. I tried 4 differnet types of pads in the back of my R33 (Bosch, RB74s, and others) all squealed like buggery no matter what i tried. It drove me up the wall and sometimes i just didnt want to drive my car as it screeched so much. I have slotted rotors, stock calipers, nothing flash. Got some second hand Nissan pads for rear, and the first day they went in i had a little tear in my eye, not a single screech.
Not even a squeak since, months later, soooooo relieved.
Just put an ad in WANTED section for second hand Nissan pads, they are dam cheap and someone always has some lying around.
I only have Nissan ones on the rear, i have RaceBrakes RB74s on the front. The fronts get a bit noisy every few months with too much city driving, then a few high speed stops on the freeway burns the crap off and they are good as gold once more.
Good luck on your quest mate, its a relief at the end when they are dead silent all the time. :)
same boat mate... i put rb74s on the front with new dba 4000s aswell and the squeeking is hideous... it does it when the brakes get some heat in them... when you pull up at the lights it happens when the car has almost come to a stop. drives me crazy.
Brother put on 4000s with bendix advanced pads and same thing... tried everything you have but couldnt get rid of it.
Sounds like a common annoying problem many of us share. Anyone use other performance pads with dba 4000s that dont sqeak???
    • This is for an RB20DET. Sorry for not including that.
    • Welp, this is where my compression lands after my rebuild. Thoughts? I have ~6 hours on the motor.
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
