R34 GTR the same?
The ratios are different but they will all do those kinds of speeds if the power, strength of drivetrain and wind resistance is all living in 'the perfect world'.
Obviously there are restrictions and this is based on the estimate of ~3000rpm in 5th at 100km/h and every 250rpm higher is ~10km/h faster.
The easiest way to tell is to do 100km/h, note the revs, then go up 250 or 500rpm and use this to calculate your top speed at redline.
Keeping in mind that it will require approx 450hp at the wheels to go around 200mph and another 100hp at the wheels to go another 20mph. This is approximate also as relayed to me by a mate of mine who races on salt lakes.
https://www.sau.com.au/forums/topic/255085-gtr-topspeed/#findComment-4401169
just trying to figure out (i have no idea if im right) but say you made 7000rpm the limit, would not all the cars of that model have the exact same top speed because of the final drive/diff ratio?
if in theory you could reach it power wise????????
https://www.sau.com.au/forums/topic/255085-gtr-topspeed/#findComment-4401163
They do not all have the same gear ratios.
There are different things that will effect the top speed: Gearset ratios, diff ratios, tyre size, top rpm, and finally the car's wind resistance.
But yeah, if you have 2 R32GTR's exactly the same, they would do the same speed at 7k
https://www.sau.com.au/forums/topic/255085-gtr-topspeed/#findComment-4401176
hey thanks for that :D
robbie
https://www.sau.com.au/forums/topic/255085-gtr-topspeed/#findComment-4401175
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
