Hi All,
I've been told that the max boost you wanna push out of a stock Rb26 is about 20psi.
Is that about right?
What do I need to strenghten to be able to up the boost further.
I have turbos that can support more boost.
Cheers
-Michael-
https://www.sau.com.au/forums/topic/255191-increasing-boost-questions/
stock rb26 are good for around 300-330kw but all depends on how much power you want and for how long?? you can run more boost on stock 26 but how long it will last before rebuild is anyones guess.. what turbos do you have??
I have 2 x Trust T517z's
What do you need to strengthen? Like the whole motor. and other engine support mods like oil cooler and oil restrictors etc.
To get more than 330 awkw then you need to spend the real big bucks, so unless your going to the track every weekend then your not really getting your money's worth imo.
So yeah your looking at lotsa dosh for more boost and more power.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
