what temperature should your car run at?
I've got 2 temperature gauges, one is on the outlet of the radiator, the other I believe is on the inlet.
The temperature gets up to 105 deg C, it's half-way on the factory gauge. I'm not loosing any coolant, I have new thermostat. In a cold but sunny day, driving on a highway, it gets to about 80 deg C on one gauge, and 105 deg C on the other. Is that normal? should it run cooler?
I found cheaper fuel makes your engine noisier, so i never put normal unleaded.
https://www.sau.com.au/forums/topic/255200-need-help/#findComment-4403701
i use caltex 98 / it normal is about 69-70 C on a normal day but these hot weeks its been running hotter i might need to get some new plugs then yeah its normally around the 26-45 knock range and at times if the fuel is shit it peaks at 65 but this is the first time iv seen it get this high
https://www.sau.com.au/forums/topic/255200-need-help/#findComment-4404540
Where I can I run of BP ultimate and it always stays within a good range, when it's hot gets up towards 40.
Had to put Shell 98 in it a few times and its been running well enough on that past week or two.
I don't like Caltex fuel, maybe its changed but had some bad experiences with my last Skyline running like a bitch on the stuff so I have never returned!
https://www.sau.com.au/forums/topic/255200-need-help/#findComment-4404601
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
