  • Replies 51
Posted Images
hi,
just wondering if the nismo exhaust is still up for sale and if the exhaust will suit an R34?
yes its still for sale but i have no idea if it will fit a r34 sorry?
Would you consider a swap and cash your way? I got a Kakamoto 2.5 inch stainless steel stage2 exhaust. Brand new I was told it would cost over $1K.
no i wouldnt swap im selling my car anyway just want the cash
yes this came off a r33 gtr yes pick up only unless you want to pay for delivery
Oh.. that raises another question for me... I thought I read some posts about GTR exhaust hangers being in a slightly different position to GTST hangers...
I think I need to find out definitely. =-]
I'd be willing to make an offer if all is well.
Thanks!
  • 3 weeks later...
NISMO EXHAUST STAINLESS STEEEL
3 INCH FROM CAT BACK 5 INCH CARBON FIBRE TIP
TO SUIT R33 SKYLINE JUST BOLT ON NO MODIFCATIONS
NOT YOUR NORMAL TINNIE EXHAUST PRETTY RARE
$550 PICK ONLY ANY QUESTIONS PLEASE CALL TOM ON 0422305506 OR EMAIL [email protected]
Can you find out how much it is to ship to Perth 6014? Cheers.
through an online quote your looking at around $180-200 which included insurance and packaging now that could change on when they see and weigh the item
Right, are you 100% certain it's off a 33 GTR cause its on a 33 sedan in the pic... Reason I ask is because I bought an R33 exhaust before and it didn't fit because it wasn't GTR specific.
edit: my bad.. read its only a 3" from catback.. thanks anyway
Edited by Ten Four
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
