Howdy. I've got a S2 R33 GTs-t here in sydney for wrecking. It's had a hit up the back, so the tail lights, rear bumper, and bootlid are gone.. rest of the car is up for grabs though. If youre after anything send me a PM or reply here! Pics at the bottom of this post
It's a '97 S2 R33 Gts-t with approx 146000 ks, Silver/KR4 in colour.
BBS Impul wheels + Falken tyres - $1000 ono
17x8 and 17x9. Rear tyres are on the tread markers, fronts have about 40%. Unsure of offset as its not written anywhere on the wheel, but they fit R33s perfectly. great condition, just a few small gutter marks
5sp Manual gearbox. Shifts well, no crunching. Includes slave cyl, crossmember, shifter and tailshaft - $1500 ono
Can sell as a manual conversion kit if anyones keen
Front end stuff:
S2 front bar - paint has flaked/chipped off in some places, needs respray. includes foglights - $350 ono
S2 grille -SOLD
Front guards - $100 each
S2 headlights - $500 firm pair
S2 bonnet - $250
A/c condenser - $150
Radiator & shroud - $100
Front reo bar (has been cut for FMIC) - $120
Radiator support/ nose cut - $150
Engine bay stuff:
S2 Rb25 turbo with actuator, good cond, minimal shaft play. Didn't blow any smoke - $250
Impul Hi power control unit remapped ECU - $200
S2 Rb25det engine loom - $150
S2 Rb25det coilpacks - $100
S2 AFM (pink sticker)- $90
R33 aircon compressor pump - $100
R33 power steering pump - $100
R33 alternator - $80
Engine Mounts - $80
Fuse box lid - $20
Washer bottle - $20
Radiator overflow bottle - $20
Charcoal canister - $30
Stock airbox & snorkel + filter - $75
Stock SMIC piping - $50
Stock sidemount intercooler - $40
S2 ABS pump - $100
Bm-44 ABS brake master cylinder - $80
Exterior & suspension/brakes:
Side mirrors - $50 each
Rear SKYLINE garnish (silver) - $40
S2 spoiler minus brake light - $50
Stock suspension with lowered king springs - $250
Front lower control arms - $70 each
Front upper control arms - $40 each
Front hubs - $80 ea
Rear lower control arms - $50 each
Rear 5 stud hubs - $160 pair
Handbrake assembly & cables - $160 pair
Manaual (4.11) ABS diff - $250
Driveshafts $50 pair
Rear upper arms - $50
Front calipers - 250
front rotors - $50
rear calipers - $150 pair
Rear rotors - $50
Interior stuff:
Boot interior, sides, floor, carpet etc - $100
Drivers door window switch - $75
Drivers window switch surround - $40
Drivers door motor/regulator - $80
Passenger door motor - $50
Door trims - $50 each
Instrument cluster with 300km Impul speedo. Unfortunately odometer has stopped (everything else works though) - $150
Dash surround (with clock, hazard switch etc) - $80
Gear stick surround - $50
Ashtray - $25
Glovebox - $40
Steering column surround plastics - $30
S2 dash pad (with passenger airbag & panel) - $350
S2 Steering wheel with airbag - $250
Centre console - $50
Front seats (drivers side has a tear in the usual spot) - $100
Rear seats, good condition - $50
Seatbelts, full set - $80 (will seperate)
Ignition barrel + door barrels + key - $100
If you're chasing any little random bits that arent listed, shoot me a PM. Cheers
post-35556-1233651201_thumb.jpg post-35556-1233651214_thumb.jpg post-35556-1233651188_thumb.jpg post-35556-1233651118_thumb.jpg
https://www.sau.com.au/forums/topic/255421-wrecking-s2-r33-skyline/
  • Replies 68
Do you have the sideskirts? Interested if you do.
Sorry mate the car didn't have sideskirts
Drivers side swtich, window motor/reg and switch surround sold pending payment
Will add some more pics soon!
interested in the manual conversion kit, how much would you want for it?
Hey, PM sent
hi could u tell me about the computer , is it running stock boost
Hiya, as far as I know it was runnning stock boost
Hi
I am after the motor that makes the mirrors go in and out (passenger side). Is this a part of the mirror assembly?
Could I get photos of the mirrors, drivers and passangers.
Also do you have the break light for the S2 rear wing?
Cheers
sent u pm last night..
keen on brakes..
Heya, Pm replied
interested in ecu...wot sort of gains were seen with this place? fuel economy?
is the silver rear garnish is good condition, where u located?
cheers
Sorry mate not sure of the gains as it was never dyno'd or anything. It would have a more agressive fuel map, modded timing, speed limiter removed etc
Silver garnish is in great nick. Pm sent
Hi
Cheers
Hiya, I'll get some pics of mirrors tomorrow for ya. Just looking to sell the mirrors complete (with glass, motor, shell etc)
Don't have the brake light sorry, just the spoiler by itself
cheers
Heya, Pm replied
cheers
Still after pics of mirrors, want to see the condition (scratches)
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
