yeah she is doing really well atm
still havent done a power run.....lol my laziness
just been focusing on other stuff atm and just making sure she gets her services on time and what not but she is running awesome could ask for much more atm
a couple of pics from a quickie photo shoot on thursday night pics where taken by Michael Coppola
front bar is getting taken off on the 3/4 march and getting fixed up majorily....so many stone chips and fractures in it :blush:
then the rest of the graphics will be going on :D the rear end of the car will be changed. the graphics will finish at the bottom of the bar instead of on the boot lid, and the roof will be done aswell
defintly will post pics up when that is all done. till then enjoy these two:
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
