what do u wanna know about the kooler man it was in the car when i got it so i dont have much info on it , not sure about sun roof mate mine doesnt have one n i havent seen the inside or one with a sunroof to say, yer hicas lock i still have
how thick is it? and with the sunroof do u have pics? as for hicas lock bar can i have info to come get it and look at the cage and cooler. pm me if u want
  • 3 weeks later...
  • 1 year later...
im about to start srtipping my 32 everything is for sale here are just some of the things going of the top of my head but theres prob more so just ask if your after anything
engine 180 000 k's split fire coils standard turbo $700 ono
gearbox $300 ono
diff $200 ono
tien suspension $400 ono
sructbraces front n rear $100 each ono
rollcage $500
hicas lock bar $50
r34 standar suspension $200 ono
r32 aluminium radiator $200
32 std radiator $50
r34 std radiator $50
r34 front sway bar $50
r32 std ecu $50
interior bit everthing bar air con vents let me know what your after n i'll give u a price??
apexi pod filter $100
sterring wheel $50
boss kit $50
exitior bits let me know what u need n i'll give you a price
reclinable seat $50
full 3" exhaust system with screamer pipe $200
these are just what i can remeber if your after any thing for a 32 let me know n i'll see if i have it
Is the car a 2 or 4 door?
have u got the windscreens front and back
and the plastic panel thats at the bottom of the front windscreen on the out side and does it still have the clips?
pm me
thanks
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
