im just wondering how you can get that power with a gt35.. your 850cc injectors must be right on there limmit.
stock valve spings and 30psi? and standard cams. got a dyno sheet so we can have a look?
  • Replies 136
That's not what I was saying at all. Forget the ET. It's irrelevant. What's a full-weight RB S13 weigh? Not as much as a full-weight Skyline I'd imagine.
My point was that the 128mph doesn't match that car with 600rwhp. That's all.
And dyno figures are about as relevant as post counts.
I love how everyone assumes ideal real world case’s in every single situation. I don’t control dyno calibration. 2 out of 3 where within each other, one was less (lets call the lower one closer to correct) for the sake of this discussion.
Next time I’ll have a rabi over see the dyno :happy:
thats great! so lets see it then? after you get it blessed of course.
See what? a dyno run + Rabi? I’m not actually arguing over the power being right or wrong. It ran a 10.8 at 128mph, it made happy power on a machine I do not control. If 128mph means less HP in real world testing, then so be it. What are we all trying to prove here?
AFAIK the guy I sold it to now runs an auto, keep an eye out at Willow Bank I guess :happy:
All good mate. I believe that your car made 600 and that it ran 128mph. I was just suggesting that the mph doesn't support the dyno.
And Ive been suggesting like 90% of dynos its probably incorrect. I thought this was about old mate saying my mph didnt match up with the ¼ mile time, not mph matching up with dyno print off.
2rismo is right.. that mph does not match the time.
jesus what a way to jack my thread..... yea i know your messing antony still not cool though, i always though my car had 640 crank hp back when i ran at 29 psi with 3 degress less timing i put the timing and the extra pound and it did feel like a 30+hp gain, and as for the dyno its a brand new mustang dyno its 1 of the lowest reading dyno's in the us its nick name is the heart breaker..... my freinds gt4092r talon at 38 pounds of boost dyno'd 571 awhp ... normal?? i just dont like it when people think thier stuff is better or more right then some 1 elses just cause of where they live or got it from.... ill get the sheet for you in about 30 mins when i get to the dyno
CYA haters.....
CYA haters.....
come on mate.. we aint haters.. we just have different horsepower / kw then you do. Your MPH is about the same as mine and i had only 374kw at the wheels on a proper prepped track.. the MPH tells all.
Your car may have that much hp over there, but over here its a different ball game with different dyno's... we often hear bogus power figures come out of the US that we cannot work out how.. we have the most support - more parts cheaper available to us then anyone else around the world and we been playing with imports longer then anyone else so its not because we do not know what we are doing. Its just the readings that are different.
So tell me how did you go in Chille?
thats bs man bring your car 2.5 vs 3.0 pump vs pump ill smoke you, i have 50 hp more then that time i raced and you forgeting the weight diference between our cars and drivers and i dont care if you invented the damn engine dont mean my numbers are bogus
when you get a low low 10sec quarter and 140ish mph then it will seem more realistic.
I've been waiting for someone to say that guilt man. Forget the et if his track is as dusty and shitty as he says then its unlikely he'll get the times. The mph is the litnus test tho. 130 doesnt cut the mustard.
No doubt its a tuff car and good luck to the owner/builder but unless the strip is on a 45 degree uphill slope those numbers simply do not equate to 600 plus hp.
when your looking at my rear lights it will seema little more realistic also, btw the mustang dyno was designed in australia and mustang dyno's software and formulas are made and written in australia
And I’ve been suggesting like 90% of dyno’s it’s probably incorrect. I thought this was about old mate saying my mph didn’t match up with the ¼ mile time, not mph matching up with dyno print off.
100% mate. I was disagreeing with GT and clarifying my point. We're on the same page :-)
not good with the whole reading thing are we i ran the 132 trap back when the car had 50 hp less less boost and less timing and my car weighs 1580 kilos with driver
Look Raegan, no one is denying your setup is tough, you have the quickest car in your class in your country and you do it all yourself which is friggin awesome. Its a great credit to you and whoever helped you.
What happened in Chille? post up pics!!! post up dyno sheet as well
and as for you floggin my car... Everyone talked it up and said that to me has learnt the hard way.. besides i am over drag racing i don't even think i will drag race it again.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
