hey all,
I was planning on changing my gearbox oil this weekend as I haven't done so since owning the car. However, I was just reading something about the ATTESSA 4wd on GTS-4's and the transfer case for the front diff.
Now, my question is: Is changing the gearbox oil in an R32 GTS-4 just as if it was a GTS-T? I mean, does the transfer case run off the oil in the gearbox? Or will I have to drain the transfer case aswell and fill that up? Or does it run on special oil?
Does the transfer case even have oil in it!??
I would greatly appreciate all and any help on this,
thanks
https://www.sau.com.au/forums/topic/25572-changing-gbox-oil-in-r32-gts-4/
transfer case has oil in it thats for sure , i'm not sure what type it has in the gts-4 but the gtr has atf ( auto trany oil ) and its not the same as the g/box it has its own drain and level plugs .
Wrxhoon is spot on, the GTS4 is virtually the same as GTR as far as the transfer/gearbox side of things, (although from my experiance the gts4 has a weaker gearbox main input bearing and a weaker non-boosted clutch) but the main layout is still identical.
Gearbox has its own level and drain plugs as does the transfer case, For the R32 GTR and GTS4 nissan recommend you use in a nissan gear oil MP-G special GL-4 #75-90 approx 4.1 litres or similar rating gear oil. ( I use fully synthetic)
Transfer uses nissan automatic fluid D Approx 1.8 litres or similar rating fluid.
MEGA
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
