Heyyas.
I have a BRAND NEW set of 6 1000cc top feed injectors for sale. They are HKS light blue injectors, simmilar to Sard items.
They fit standard rb26 fuel rails and mabye rb20 ones too, can fit rb30 if you remove the 'o' rings off the ends and fit hoses on the ends of em.
These retail on nengun for around $300 Each, Selling for $1100 on their own or $800 and a good cleaned set of GTR Injectors.
Can post if bought outright but pick up only if swapping with other injectors. PRICES ARE FIRM AND WILL NOT NEGOTIATE!
I also have a brand new Trust clear RB26 timing belt cover. Brand new in box and not a mark on it. The trust ones retail for $150 selling for $80, can post.
**MORE BITS**
I have a front half of an R33 GTS-t tailshaft, excellent condition, perfect for conversion and a Manual cross member with mount $50 the lot PICK UP ONLY!
  • 1 month later...
  • 3 weeks later...
Heyyas.
I have 700cc and 650cc injectors would you be interested and if so how much change over thanks.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
