Parts and Fluids changed during full service 1 month ago:
All brand new Genuine Nissan Parts
Timing belt
Water Pump
Thermostat
Cam Seals
Crank Seals
Tensioner Bearing Spring
Timing Belt Idler Bearing
Timing Belt Tensioner Bearing
Ancillary Belts (Water Pump/Alternator, Power Steering, Air-conditioning)
Front and Rear Diff (Motul)
Gear Box Oil (Castrol)
Transfer case (Castrol)
Engine Oil and Filter (Motul)
Iridium Spark Plugs (NGK)
Brake Fluid Flush (Martini Racing)
OEM Brake Pads
Coolant flush (Castrol)
Fuel Filter
Bridgestone Tyres with 80% thread
Modifications:
HKS Hi Flow Panel Filter (Brand New)
Fujitsubo Cat-Back Exhaust
Trust Turbo Timer
Factory N1 front bar
Factory N1 headlights (HID)
Remote central locking with immobiliser
Engine Compression report available.
Immaculate 11/1993 Built GTR for sale. I am the first owner in Aus. The car is stock standard and was complianced in November 08. I bought the car late last year from an import dealer with the intention of making it a daily driver.
Car is in excellent condition. It even still has the engine undertray and brake cooling ducts present.
The car was recently given a full service with the intention to keep it in excellent condition.
Genuine reason for selling - Decided to go for the R34 GTR instead. ;)
Nothing more to spend if you want to keep it stock standard. Service and parts cost me nearly $2500 and they are pretty much brand new. Receipts available. Feel free to arrange for an inspection.
Dan: 0401486813 Located in Melbourne CBD
Let me know if you need more pictures of the car.
Asking for $21990 but reasonable offers accepted.
Edited by r32gtrrocks
https://www.sau.com.au/forums/topic/255758-november-1993-r32-gtr-for-sale/
Price Drop to $20,990
Call for inspection :D
Hey Dan,
How many kms have you put on since having it imported? and are they genuine kms? Seems quite difficult to find a clean r32 gtr with those numbers on the dial. Must be a smooth drive.
Can you PM me your best price? coz I'm interested but i guess only if the price is right.
Thanks,
Yao
I only put 1000kms on the car.
Initially plan to drive the R32 for a year before getting the R34.
But the way yen is going, I thought may as well take the chance now and buy the R34s that came in with good exchange rates.
So really would like to sell the car.
It is in very good condition guys. Nothing more to spend other than to modify it.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
