  • Replies 71
i got a mates steering wheel on with just putting it over my boss kit, the horn worked, then it didnt and we are like wtf? now when ignition is on i have a AIR BAG light which i have never seen before in my life.. let alone my series 1 even have air bags :s and now the horn doesnt work at all checked all fuses and everything we're just stumped.. we got a wheel on but now no horn wtf!
https://www.sau.com.au/forums/topic/255886-defected/page/3/#findComment-4416426
can series 1.5 have just a drive air bag and no passenger?
edit : mines a 95 and when i got it came with a s2 wing, s2 floor mats, s1 rear garnish, s1 front bar and lights
Most S1.5 only have a drivers air bag, S2 got driver and passenger, judging by the year and all the S2 i think there is a good chance it is a S1.5, maybe even a S2.
Do you have an igniter on the coil pack cover up the back, S2 dont have one.
https://www.sau.com.au/forums/topic/255886-defected/page/3/#findComment-4416454
Hey,
Pretty sure most S1.5 has only drivers airbag, can't remember when I last see S1.5 with dual airbags, You might need S1.5 airbag steering wheel to pass RWC.
Hope it helps.
*edit* Brett, aka W0rp3D beat me into it.
Edited by Count Grantleyish
https://www.sau.com.au/forums/topic/255886-defected/page/3/#findComment-4416461
hrmm thats weird cos when i bought the car it had the 'metal middle bit' steering wheel on it so i just thought it didnt come with a air bag.. maybe if i try my brothers s2 steering wheel.. he just bought a s2 r33 (white as well -_-)
https://www.sau.com.au/forums/topic/255886-defected/page/3/#findComment-4416483
yeah i spose you can borrow my wheel on the weekend Leigh - if you help me with my clutch :D
https://www.sau.com.au/forums/topic/255886-defected/page/3/#findComment-4417500
if you can fit the s1 steering wheel and the Airbag light is your only problem, you need to find the wires which used to plug into the airbag. Then you just need to buy a resistor from dicksmith or something and just solder it on or plug it into the plug. this should trick the system into thinking that the airbag is still there and should work fine.
sorry i can't help with what the resistance is supposed to be, i'm sure someone on here would have done something like this.
https://www.sau.com.au/forums/topic/255886-defected/page/3/#findComment-4417531
yeah i spose you can borrow my wheel on the weekend Leigh - if you help me with my clutch :thumbsup:
hahahaha. +1
yeah globe is your best bet.. or alternatively you could try getting it cleared with that holden steering wheel :)
https://www.sau.com.au/forums/topic/255886-defected/page/3/#findComment-4417712
heres a couple of pictures, see the plug thing on the yellow circle, it just doesnt fit through the slot of the wheel slot, and even if it did the plugs at the other end of the wire dont plug into each other.
https://www.sau.com.au/forums/topic/255886-defected/page/3/#findComment-4417855
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
