Good Day all,
About 2-3 weeks ago my car starts to shake after i turn the ignition on. It will go away after a minute or so after i drive outside of the driveway. Occurs randomly. Thought it's something normal so i left it as it is.
Few days later when i start driving on the freeway the same thing will occur. The car will vibrate and shake for a few seconds. If it remains shaking / vibrating after a minute or so all i have to do is boost the car and the vibration will go away. This will occur when i'm driving about 70-80km/hr at the freeway. So what happens is i'll boost it to 100-120kph when the car vibrates at say 70kph and the vibration will just go away (not sure if this makes any sense)
So today arvo me and Brendan jack the car up to look for any exhaust leaks (checked out fine) and we also took apart the AFM and cleaned it with a electrical contact cleaner but it's still the same.
Also just drove to the city and along the freeway the vibration is getting worst. Was basically vibrating from my place all the way to the city. Tried boosting the car like i used to do but it seems to take longer to get rid of the vibration this time. Also noticed not gaining that much power when boosting the car as before and the exhaust is bloody loud now. Making a funny grumbling / misfiring sound.
Vehicle is basically stock. R34 GTT Series 2
Apexi pod filter.
Blitz Nur Spec Cat Back
Just changed my spark plugs last service from copper to NGK iridiums BKR6EIX gapped at 0.8mm
Any suggestions / help guys ?
exhaust from what i heard is a very slight mis firing problem...
the coil packs is what we planning to look at next after eliminating exhaust leak, afm, sparks. Im assuming its only just starting to go a little bit hence the randomess of the problem occuring.
Best recommended way of testing coilpacks would be? Replacing all of them spitfires? or maybe using someones elses coilpacks to see if it fixes the problem.. and if it does then buy the coilpacks?
Or is there a way to test using a multi meter?
it sounds like it may be your coils starting to go. you may need to look into that.
by vibrating is the car surging with a strange exhaust noise(ie popping/misfire)?
yeah the car will surge with the strange exhaust noise
it's like a spluttering noise (i.e. putting an empty bottle and submerging it into a pail of water - those kind of sd if you get what i mean)
It could be a vacuum / boost leak,
Check your intercooler and piping etc
if that was the case wouldnt the car have trouble holding boost?
His car holds the boost no problem...
Suppose it couldnt hurt to hunt around for the vaccum lines tho.
the coilpacks are a common problem, does it miss fire under load, say accelerating and does it start to do it around 5000rpm. if yes then l can safely say it is most likely coilpacks, if not try swaping in a known good set of coils and then try and if that fixs it buy some spitfires. Coils can be tested with a multimeter but it wont show up a intermitant fault like skyline coils have, because they have a problem with sealing and the spark jumps out the side of the coil in stead of tracking down the plug.
You can try taking the spark plug cover off then try driving the car at night and when it does it, look at your coils while the car is running and see if you can see any spark flashing around(sometimes you can see it in the dark). If yes get new coils.
hope that helps
gee you sure got lots of guessswork replies - you need to start methodically - first you check for engine fault codes - takes about 1 minute and you only need some wire to do this - if you don't know how, search the site (its been covered maybe a million times)
and why would someone tell you to replace the coils or even check them unless you get a definitely got a Code 21 ?????????? bizarre!
see what fault Code you get if any- you may not get one come up at all, but even that points you closer to the real problem and figuring out what needs doing
if no code comes up it maybe something as simple as water in the fuel, blocked fuel line or filter, or dying fuel pump, among about 15-20 possibilities
I agree with this reply 100% and just to add to those 20 or so possibilities you could have leaking intake manifold gasket as I do and sometimes misses on idle.
Good luck!
Dave
Tried opening my kick panel to check on the ecu but it seems to be stuck. NFI so i'm trying the pin method via the fuse box under the driver's dash
Tried the pin method and ............... 5 short blinks and 5 fast blinks which means code 55 - no malfunction
Ok now what guys ?
p.s. This test was done without driving the car for 10 minutes to warm up the car. Will this give out a false reading (55) ?
Edited by hotchoc
yeah do the test codes thing but if it sorta sounds like a wrx when it starts shuddering its most likely the coils, could be simple like the coils clip isnt connected properly, thats what my problem was, i just opend the plastic cover concealing the coil packs on the engine and clipped them all in properly.
also this may fit the reason why when you boost it goes away, you boost it, all the parts of the car that arnt fastend to the car in some way will move and this could mean that the connection is made again, its also better to check this now instead of later because ultimately this will damge the coil if it is a connection problem. then your up for $400 ish for a set of new decent coils.
this worked for me but it could be many other issues aswell, coils could just be on the way out, even a sark plug that is fouled or dying ect.... but it sounds like something to do around that area anyway...
also i really doubt its the exhaust at all, i ran my car for a bit of fun while chageing the front/dump pipe with no exhaust from the turbo back.... awesome sound, no shuddering, just sounded like a drag car...
As I was saying before on msn, give the coils a proper servicing before you go out and buy splitfires.
- remove the coils
- remove the boot, clean, and then hit it lightly with silicon spray
- using a metal brush, clean the tip of the coil pack
- reconnect it.
but if your coils are on the way out, no amount of servicing will bring it back to life.
ecu won't always give you a fault code if it's coil related.. it might if it was a power transponder though.
oh one more thing, if the coil packs are not secured properly will the fault codes show as 55 as technically speaking there's nothing faulty with the coils but just a loose connection right ?
I didnt get any fault code, and my coil plugs were loose because the mechanic doidnt clip them in, the car ran fine for 2 day than i went over a speed hump and the problem started....
  • 4 weeks later...
just a small update ^
took the coil packs out and sprayed it with a contact cleaner and used a vacumn cleaner to suck out all the dirt and leaves (yes don't ask me how it got there) near the spark plugs
now the problem is gone - just hope it'll stay liek that for now
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
