stretching = less tyre on the road as well which is a good thing at the back when your talking drift.. although not so much the front, but i'm assuming they dont stretch em as much up front? If you want good grip you don't want to go stretching for exactly that reason, less footprint on the road = bad, like overinflating your tyres.. If you want less sidewall flex go lower profile not thinner tyres that don't fit
Hard to find proper tyre joints that will stretch too but, i like the look, looks sick
i used to rip the tyres off my dirt drifter all the time because as it went sideways the tyres dug in a bit and just peeled off.
if i had of stretched them then they have less change of peeling off,
thats one reason that i have found and been told about.
dont do much circuit/track so cant comment on that.
interested to find out more tho.
cheers
Gezza
I too am a fan of the stretched look.
I have run 225's on a 6.5in rim and a 205 on a 8in when drifting.
With the stretch it does feel tighter and more responsive in the rear. I think thats the only performance benefit. Less sidewall flex.
The bonus is of course their also cheaper. Drifter pushing a decent amount of power will go through 5 or 6 PAIRS of rubber in a drift day and still need more. It becimes very expensive. So even a little bit of saving due to smaller sizes adds up
they look like the good ol drifteks.
flicking through a few, well, alot of hpi mags last night and found quite a few time attack entrants go the stretch.. some do, and some dont.. these guys arent cheap kmart boys.. and can destroy a set of big dollar semi slicks within a few laps.
something else to think about.
cheers
Linton
cheers
Linton
Alot of cars int he hpi mags (& others) claim to be time attack but it is clear from looking at them that they have either never been near a track or if they have are hopeless. Brakes that look like brand new, hopeless spring rates & no negative camber are just some of the things that give the game away. If you look at an R compound after it has been used properly it is a very ugly tyre. Be aware also that some of the workshop cars will be on what are basically show rims/tyres ie not what they run at the track.
Tooling about seconds off the pace does not make a good track car. Just like stretching a road tyre does not make a good track tyre. Any half decent track car will use the correct tyres - either a r compound or a slick. Both of which have the carcass construction to obviate any need to stretch anything.
Look if you want to do it because you reckon it looks fully sik then go ahead. But please don't advocate it as a preferred alternative to anyone who is in any way serious about a good lap time.
If people want to use them for drifting then good on them.
it was not feature car article... it was in articles about time attack events, at tskuba and the like.
and track cars aside.. what if i dont want to go to the track.. what if want something that will tear something like the putty road apart.... this is why i started this thread.. and compared it to wrc cars on tarmac... as they arent on a race track, they are on an average road.. you already mentioned the reasoning for some of them having stretched tyres.. i just made the mention of d1 teams and time attack teams to combat the "kmart" response.
cheers
Linton
as far as safety goes: not an issue unless ur going over like a 18x10 with a 215/45 range, some will be fine, but it depends on each tyre and rim, some tyres are better at stretch, some rims are better at stretch (bead seat design). but for most stretch like a 215 on a 9", ull be fine.
looks: personal taste
performance: can provide less traction (as opposed to a same size tyre on a thinner wheel), but will firm up the sidewalls, hence it is popular for drift, it means u dont have to run high end tyres to get a tyre with a solid and predictable sidewall. afterall drift is about control and predicability, sacraficing a bit of traction/speed for more predictability often makes sense
ride/comfort: there will be a slightly harsher ride, as well as tracking as there is less sidewall compliance, no different to performance tyres with hard sidewalls tho
from the pics ive seen... they arent stretched, as like you say, a 215 on an 18x10... but they appear to be slightly angled in as opposed to straight up and down and inline with the edge of the rim.. hence my reference to them.
cheers
Linton
Good writeup but you missed one of the key things needed to set a good lap/stage time.
Lateral grip.
Now despite all the hype this is obviously going to be less of a consideration in a drift car than a track car. So one of the fundamental concerns for anyone on a track setting times gets ignored. Stretching a tyre does nothing for lateral grip.
Stuffing as much rubber under the guards as you can does help. If you ever get the chance to look under a touring car running unrestricted rubber you will see the guards are a mess of black where the tyres are in contact over bumps etc.
Lateral grip.
not sure how i didnt cover that, pretty sure i mentioned grip, including lateral grip.
grip is very important in competitive drift, being able to carry more speed into the corner, as well as through the corner and out of the corner, saying that having a tyre that flops around takes a lot of feel and response out of the rear end, especially on change of direction etc. is pretty shit to drift with.
u can get away with a bit of a faint rear end with racing, as long as overall lap time is better, but drift is a different story.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
