Forgot to mention, in Japan the age of the car is based on the year it's registered, not the year it's built, so your car would've been a 1995 in Japan, and a 1994 here. Interestingly enough I plugged your car into another online chassis check I use, and it came up blank - so then I upped the chassis number to BCNR33001350 and it came out as January 1995.
Edited by Iron Chef
https://www.sau.com.au/forums/topic/256400-r33-gtrs/page/2/#findComment-4420898
I haven't got FAST on me (I'm in Japan till next week) but I can almost bet that what I said earlier is correct. Your car would've been amongst the first 100 to hit the streets :P
Ah, old car :( makes it even older saying that haha.
https://www.sau.com.au/forums/topic/256400-r33-gtrs/page/2/#findComment-4420941
well the disadvantages of buying an early car is that......it will most likely have all the Manufacture faults that have not yet been either recalled or corrected.
usually the last series is always the best......
but the problem when buying last of the series is that, your about to be out dated with a new shape & u wont be original anymore.
where as when you buy the first when its released...you will stay original for a fair few years.
https://www.sau.com.au/forums/topic/256400-r33-gtrs/page/2/#findComment-4420958
Yeah, ah well.
So, it is 95 model or 94 model?
I'm so confused, what does the fast database do?
hey owgasm......im CONFUSED with something too.......
you car.....i was having a bit of a sticky beak on your website.
and i recall seeing/reading your story about your car a while ago.
is your car an actual R34 GT-T but converted to an R34 GT-R???
cause some of the body on it doesnt appear to be GT-R, neither did your old wing...
as well as your motor.....it seems like its the R33 GT-R Rb26DETT with the black cover.....
from memory it was posted saying it was a GT-T ---> GT-R conversion....
https://www.sau.com.au/forums/topic/256400-r33-gtrs/page/2/#findComment-4421203
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
