  • Replies 40
  • 4 weeks later...
I can't believe that these controllers are not snapped up like hot cake.
My car used to literally "walks" under full power even with a front lsd and sticky re55s.
The unit not only stopped that but made the car more controllable around corners, especially so in the wet.
I won the QLD Nissan time attack day last year thanks to this unit. It was a very wet day and most people with slick or semi slick tyres were all over the places behind the guys with less power and street tyres. I had semislick and this unit made the car so controllable.
I've not had enough track time with it to fine tune the settings but it will be awesome with some more R&D. I cant believe that it's out of production so soon :devil:
Edited by 9krpm
Have bought it and it arrived just before Easter *I think* its the correct size to replace the ash tray, not sure how to wire it yet, the instructions are there, I'm just nervous about doing it and not 100% sure about where the wires are...
i intall these controllers but i suggest the airfare and accom. charges would make it out of the question to do yours.
Ha ha, if you do drop by Melbourne anytime soon just tell me :down:
Otherwise, I'll try to install it myself, I might be PM'ing for some help though...unless I find someone else who has done it themselves on the forums.
It was too big for the ash tray, but I found somewhere to mount it, for anyone who wants to do a DIY install I wrote up some more instructions in this thread.
I've only done a brief test but seems to make a huge difference, need to do more testing to ensure its not just a placebo effect though :P
  • 2 months later...
  • 3 weeks later...
  • 4 weeks later...
Sorry guys...pm is the best method of contact.
the units left sold via pm....my fault for not posting they were gone
Ruzic Engineering has had a delay in the supply of screens for the next batch units...about 4 weeks till they are ready.
Edited by DiRTgarage
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
    • You sir, big win tonight. Precision never supplied compressor maps in the past and Idk when they started, but it seems they only offer for a few of the older gen2's which is exactly what I have. I punched in some numbers and seem to have gone with the wrong turbo. 600-700whp isn't in the most efficient area and is close to the choke line. 800whp is well off the map. Punching the numbers into a 68mm gen2 turbo map is bang on in the center. Here I was thinking going smaller would shift the power band down, but in reality it would just make it so much worst due to my rev limit. I would have never thought.
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
