i like very clean and simple installs im going to remove the rear tyre and mount amps into the cavity like alot of the americans do
Me too, but I couldn't do without a spare... I don't think anyway.
  • Replies 48
Posted Images
would be interesting to find a hires pic and try to read what spare tyre size it's using...
Do you mean tyre size in order to see the size of the spacesaver itself?
The problem is the Wheel to Brembo Caliper clearance, correct?
Edited by Stephen Thorpe
I reckon your mad if you dont have a spare of some kind. Tyres have been my ONLY curse in 25 years. I've ripped a sidewall and got a puncture at the same time once. Had the v35 one year and already encountered a puncture.
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
    • Hey all. I’m looking on replacing my speed sensor on my R33 GTR. Will the center differential need to be drained, and if so, the center diff uses ATF fluid D? I found information on the transmission, front diff and rear diff. Can’t find a for sure answer for the center diff. Any help will be greatly appreciated.
