Who Can Install Car Alarm & Sound System?
Yo, just bought a sound system today..
Its 2 front (witih tweeters) speakers (1 box) 2 rear speakers (another box)
an amp to power the speakers (4 channel)
DVD HEAD UNIT all pioneer..
PYTHON 502 ALARM SYSTEM INSTALLED
need this installed tomorrow ~!!
PAYING $400 FOR EVERYTHING....
PROFESSIONALS ONLY...... not noobs who think they can do it and might f**k something up..
Call me 0411789574
I COME TO YOU.
Edited by Awesome
doug from eastside install
love that guy :)
he does alot of installs and alarm job for guys here and NS.com. he comes to you fully equipped and does the neatest job ever.
+1 I use doug aswell he's really good comes to you and does the job farily quick and pro
His number is 0402 855 801
His business is called EASTSIDE INSTALLS
ummmm ok
if people wanted to steal your car they would steal it not matter what.
doug is well known for his service and workmanship. i dont think he will want to ruin his reputation by doing something dodgey.
i pretty much left my whole house open while he worked on my car and i was gone for a good hour or so.
so ye i can trust him
fair enough each to their own.
maybe the hundreds of ppl that has had dougs service has been lucky so far???
lol
no where is safe really. like i said if they really want to steal shit they will. you can take it to a shop to get the install done who knows what if they put a bug in there and they trace the car to your house lol
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
