I may need to sell my beloved GTR as i am building a house and will need a ute.
It is a late 1992 model Gun Metal Grey GTR with 120,000 genuine kms on the clock.
ENGINE:
-Apexi Twin Pod Filter kit
-Trust Cam gears (I recently spent over $1000 installing new belt, idler, tensioner, water pump etc)
-Trust Clear cam cover (Original comes with sale)
-Stainless steel 3 - 3.5" Veilside exhaust (Front pipes, super high flow cat)
-Changed all diff and gearbox oils 15,000kms ago.
-Oil changed every 5,000kms
SUSPENSION:
-Fully adjustable Bilstein suspension kit with Ebach springs, new pinapples, sway bars - the lot
STYLING:
-Genuine Greddy Gracer side skirts (originals come with sale)
-Jun front grill
-20% Tints rear and qaurter panel windows
INTERIOR:
-Standard
ELECTRONIC:
-2wd/4wd switch with torque split which cam with the car and i never use.
-Apexi Boost Gauge
-6000k HID head lights
-Immobilser and keyless entry
OTHER FEATURES:
-Original GTR Mats
-Still has cold air con
-Pioneer MP3/Ipod compatible Head Deck
-I just put 4 new Toyo tyres on, including a wheel balance.
-I have also just changed the brake booster as the old one leaked, also new brake fluid, brake pads are about 80%
-Tuned by Racepace, 225kw atw, with healthy dyno sheets to prove.
Have heaps of receipts to prove all work.
Everything else is standard, wheels, intercooler, ABS etc.
Car runs like a dream and has good oil pressure, starts first time everytime.
I even have Japanese log books, Nissan F.A.S.T and Auction sheets
PRICE: $19,000 or swap for a Falcon Ute.
Contact Phil on 0430 337 774.
PICS UP TOMORROW!
https://www.sau.com.au/forums/topic/256728-r32-gtr-for-sale-or-swap/
    • Kittens in first to claim dominance of the residence, then puppies later From past experience, the other way around can be problematic to say the least  Those weird "Dobby looking"  little kittens are not cheap....LOL
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
