Contact Details: PM, [email protected] or call 0403 865 415
Will ship anywhere in Australia
GTR afms (pair) - $100
GTR clutch master cylinder - $110
GTR Brake Cylinder - $110
GTR BOV - $60
Blitz sbc icolor (brand new still in box) - $850
Oil cooler with all remote fittings and braided lines (suit GTR, Supra etc) - $350
GFB manual boost controler - $60
Vee Port BOV - $ 110
Piller with Blitz guages (boost, oil temp, temp) - $220
DBA 4000 Series rear rotors (Suit all Skylines) - $320
RB20 Redtop with loom (missing some parts) - $350
RB20 Gearbox - $450
GTR shifter - $35
Pics soon
https://www.sau.com.au/forums/topic/256814-parts-sale/
GTR BOV - $60
GFB Vee Port BOV - $ 110
Piller with Blitz guages (boost, temp) - $220
RB20 Redtop with loom and computer (missing some parts) - $350
RB20 Gearbox - $450
GTR shifter - $35
BNR32 GTR Computer Retuned - $110
BNR32 GTR Loom - $250
GTR cast iron manifolds - $110
GTR Radiator Fan - $50
BNR32 GTR Cluster Dash - $25
BNR32 GTR Cam Gears (pair) - $25
R34 Pull clutch fork - $55
BNR32 GTR Center Guages - $55
BNR32 GTR Wiper motor - $35
https://www.sau.com.au/forums/topic/256814-parts-sale/#findComment-4427477
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
