  • Replies 60
Nope. It's a common misconception. People hear 10k, then tell the next person, etc.
5k will get you a full rebuild with standard parts. 10k is something that will handle 300-400kw+
6-7k is a forged build with oil mods which will handle very decent power.
Unless you're thinking... Jun stroker kit or something... which is like $15k+ all up
Exactly it can be even cheaper if you pull the engine out yourself and you buy the parts that you want to put in it..
Yer true.. but im also looking at it for like ummm speed.. like itll be quicker for us to rip it out and put one back in.... Then to wait to have something rebuilt etc...
If i didnt need a house i wouldnt have worried about the moeny and rebuilt it with new turbos... nearly did it to be honest...
i just rebuilt my RB25 (same prices, parts and labour as 26) with Arias forgies, genuine main and big end bearings, N1 oil pump, new water pump, nismo thermostat, gates belt, cometic gasket, and custom sump. Had block decked, honed and washed, head faced and acid washed, nad crank linished.
It cost me just over 5k, but i put it together myself. It took me a week to do this. By the time the engine gets here from perth you can do a mild rebuild. Pull the motor out one weekend, send crank to get machined/linished, get a set of main and big end bearings, put together following weekend. Drive to work monday, no run in required, $2000 max
i cant see how new bearings (you'll get main and big end for under 400) and a crank linish/machine, would cost more than 2k. if you wanna get rid of the car thats all id be doing. parts total might be 700 or so, assembly might be a few hundred but if you have a mechanic mate shouldnt be an issue
Assembly is around 1500 if you wanted someone to build it for you. If you have a mechanic mate shouldn't bee too much trouble. But like i said, if you just wanna get rid of it, do bearings and fix the crank up, throw a new head gasket in and you're off.
If someone was to put the bottom end together for you and you just fit the headgasket and head i dont see it costing more than 2k, maybe 2.5k.
Like i said, my rebuild cost me over 5k, machining cost me $450, the rest was parts, see what im getting at
was hoping this weekend.. but the guy selling the engine is being a bit slow... Oh and my mechanic has had a hernia op and i cant rush him to soon! so mayb next weekend now grrrr... just dragging on...
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
