Ok long story behind this question so i'll get straight to the point.
does anyone know if removing or cutting the radiator support bar will decrease general chassis rigidy ie. is it structual and forget any problems about legality its not an issue in this case.
https://www.sau.com.au/forums/topic/257351-rigidy/
When you say rad support bar do you mean the whole rad support like the pic above or just the bar that runs along the top of the radiator, i know a friened of mine was pulling his engine out so much he cut the bit along the top of the rad so it would be easier to get the engine in and out, he just made it so he could bolt it back in.
https://www.sau.com.au/forums/topic/257351-rigidy/#findComment-4437242
It is a structual point, hence why its spot welded in place. A strut brace will improve rigidity if you remove it, but some extra bracing might help. Like you can see in the pic Dave posted.
Edited by Jamesrb25
https://www.sau.com.au/forums/topic/257351-rigidy/#findComment-4437503
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
