I've been reading the brake pad thread (ie http://www.skylinesaustralia.com/forums/Br...s-t169972.html) and really need new pads..
Does anyone know somewhere in Melbourne that is not going to stuff me around eg telling me the disks need machining even if they don't (but will if they really do!) etc? I'm a bit worried about going to a random Brakes Plus...
Ian
Race Brakes - they are in Yarraville - Google them.
I have only had great experiences with them - they have always been honest and upfront.
Also you dont always have to machine the rotors when you change pads, only if they require it.
My 2 cents.
-50 for Race Brakes :)
Can't be assed and didn't really seem to give 2 sh*ts about my car. Chipped my rim to when putting the centre caps back on.
Didn't even attempt to diagnose my brake issues and the guru's answer to was to put these 11ty billion $ Endless brake pads on ($400 or $600 a pair of pads, something ridiculous). Stay away
everyone has their bad days, i dunno. That was just my experience, it wasn't a nice one, it was a fairly sh*thouse one thinking this place was meant to be the bee's knee's...
oh, and to top it all off, Race Brakes had a deal going with SAU Vic, so here i am, paid member of the club of which Race Brakes has kindly offered to give discounts, and basically treated like a tyre kicker. I'm not expecting VIP treatment, but seriously, should at least look after club members if you've bothered to be a supporter anyway
he spent hrs sorting out things for me, trying to find a match, when he could of just said cant do it, i cant reccoomned Howard enough.
he told me SAU-Vic always promised to buy heaps but havent hehe
I've had good experiences with both Traction tyres and Race Brakes. I'd use them both again for sure.
Same
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
